Please help identify this connector...
Kenneth W Larew
Kenneth
The pic is from under the truck looking up in the transmission area. This mystery connector splits off tv he main harness right about as t the firewall. It splits off the upper driver side transmission connection toward the front of the truck.
Any guesses.
We just put this truck back together after about 10 years in pieces. May be a lot of stupid questions on the way lol...
Sent from my SM-G955U using Tapatalk
Truck series and transmission type? Best guess at wire colors.
GMFORLIFE
Cleveland Ohio
Dennis
C20 Camper Special
That plug looks like it fits a sensor of some sort.
Look at the wiring diagram for the car.
Probably only fits in one connector..so it cant be installed incorrectly.
Could be the speed sensor on the transmission?
Kenneth W Larew
Kenneth
It is a four speed with o/d
Kenneth W Larew
Kenneth
Since I can't find it I'm wondering if it goes to the top of the gas tank? This one has two.
Kenneth W Larew
Kenneth
Might be yellow/green and grey
Snoots
Roger
Jimmy Sierra
That may be the over-drive control plug.
Kenneth W Larew
Kenneth
I've been looking through schematics. That could be....I'll check on it.
Snoots
Roger
Jimmy Sierra
If it is, it should plug in almost directly above where it's hanging. I can't tell from the pic and it's hard to see. IIRC, it plugs in 'downward', not inward, so you may have to get an inspection mirror and check for debris inside the connector before you try to plug it in.
Kenneth W Larew
Kenneth
That's not it....looks like it though. There is already one plugged in on top the transmission. Where it splits from the harness (right about the fire wall) it could just as easily get plugged into the engine compartment. I'll look all over again later when I get home. I havent tried the washers yet...maybe washer pump?
Are you by any chance running a dual stage accelerator pump Quadrajet because that maybe for that, which I think is what Jim is referring to about the temperature. That looks like the air injection diverter connector, but it’s too far away to be that.
Looks like yellow and grey. 85 k10
Any chance the grey wire might actually be brown that has faded? Do you or did you have an ESC system installed? If so, is there a tip-in vacuum switch mounted on the firewall?
It could be on the RH side - by the transmission dipstick:
Or on the LH side behind the master cylinder vacuum booster:
Silverado9019
