Pioneer Stereo
Stroked
Beloit, Kansas
Jared
Can I connect it to the stereo wiring harness?
That's probably not a good idea. That circuit is fused for a stereo and running the cb off of it too might cause problems.
GunMan9
Yorktown
Brandon
So do I just need to do the same as I did with the stereo constant? Run the hot with the flat to the fuse box?
robert8096
Goose Creek SC
Robert
I would not advise it. You could overload the wire and pop the fuse or in the worst case cause a melt down or fire. Safest thing to do is to give the CB a dedicated switched 12v from the fuse box.
robert8096
Goose Creek SC
Robert
Yes except find one that is controlled by the ignition switch so the CB will not always be on and drain your battery.
78ALB
