Painted interior trim.....with bedliner:
8T6K5
AZ
L98 350 TPI
A condensed version will be added to my build thread: http://www.gmsquarebody.com/forum/showthread.php?t=5266 ,but I thought I would expound upon it with its own.
My trim situation was that I had a dash cover over the oe, my A-pillars and head liner trim were gray...including the pieces the seat-belts fasten through.
My A-pillars were old and cracked, the other trim was dirty....even after scrubbing it and my dash cover was seperating from the dash.
So I said screw it, and dove in. Pulled the dash first and slowly seperated the dash cover from the oe.
While the oe dash was roasted, the cover was in really good condition, despite the prolonged exposure to AZ sun. There was a small crack up front, but nothing that cant be repaired and become invisable after painting.
I had already aquired these of CL awhile ago;
To replace these:
But, they are a different color and wouldnt necessarily match...yes, Im pretty particular about that stuff.
So the best option was to paint everything to match. I went round and round blue-gray-black and decide on black. But how to paint them, as the trim is plastic and metal and the dash was a different grade of plastic.
Then, as I was in the garage, I saw a 1G can of Rustoleum bedliner down on the bottom shelf....and my brain started working.
I had ablut 1/4G left from usng it on my rocker panels-roof and cab. I was very happy with the final results as it was not as testured as I thought. I likend it to between 200-400g sand paper.
I took an old piece of trim and wanted to see what it would look like. I hit half on an old A-pillar with 60g, cleaned with spirits and put on 2 coats. Just for ***** a giggles I did a once over, light pressure with 400g and the final product as you can see is not very textured and in fact may be smoother than before:
Compared to the dash bezel:
I thought it looked good and spent the rest of the morning sanding the rest of the trim. Im only sanding with 60g...not all the way down, just a nice even scuffed surface. I figure if this stuff is made for a bedliner it should be pretty tuff inside to AND easier to touch up than rattle can.
Tomorow I will get the first coat on, possibly a second, but everythng ready to install this weekend.
The dash I will do last, but will use the same process. Stay tuned.
Stroked
Beloit, Kansas
Jared
Cool! I have been thinking about doing this to some interior pieces. Did you use a special roller to put it on?
8T6K5
AZ
L98 350 TPI
Use a good quality brush and lay it on. A roller will pick it up as it goes over it, thus pulling it up and leaving a much more textured surface....more like you would want in your bed...not n yor dash.
However, dont expect to use it again afterwards, this stuff wont clean off. Thats why you really need to try and get all yor coats on in one day, but the stuff does dry fast....even faster out here.
Stroked
Beloit, Kansas
Jared
Hmm, I might have to find some and try it out.
Chevrolado
McKinney, TX
Dave
V8
Sweet. I bet it'll look pretty awesome. :)
Looks good. I've found the bed liner in a spray can works pretty well on interior parts too. Sucks as bed liner though, lol.
8T6K5
AZ
L98 350 TPI
Made some good progress today. Got all trim painted and finished. Sanded cover and scraped all the old adhesive off the bottom. Looks to me like they just ran a bead of scilicon around the cover and slapped it on...doesnt look like the dash was pulled
The oe dash was trash. There was barel enough for me to save it. I removed all the old adhesive off that too and too sanding wheel over the cracks to even them out so the surfac was pretty flat.
I decided I would put two coats over the oe dash, giving the new adhesive something better to grab. Then did the same to the inside of the cover.
I only got one coat on the cover, but put it on for a few pics:
The only thing holding me up at this point is wether to put the dash trim on the oe, then the cover on....or dash trim last. It almost seems as though it fits better going on first.
Also swapped these out...another item I had been holding on to for awhile:
Chevrolado
McKinney, TX
Dave
V8
Oooooh... it looks like a great look! Im a big fan. Cant wait to see the installed shots. :D Nice work!
MrMarty51
Eastern Montana
Martin
Very nice,thank You for posting the progress.
I guess I know what I will be doing when it comes time to bring the 79 in for its makeover.
8T6K5
AZ
L98 350 TPI
Might not be the best pics but....
Just need me some door handles!!
Stroked
Beloit, Kansas
Jared
Looks good!
Sent from my iPhone 4s using Tapatalk
Chevrolado
McKinney, TX
Dave
V8
Niiiiiicee! I like it too. :) Looks rough. Classic. Perfect for these squares. Nice work.
Damn Jerry looks really good.
:drool:
3dbello
