86chev
- Mar 7, 2012
- Wisconsin
- Jesse
- K20
I stumbled across a D60/14BFF combo near where i go to school. Set came out of a early 90's one ton single rear wheel crew cab, 4:10s. Axles are still attached to the frame, my question is if i go about buying the set, what will i all need to be able to swap into a K20? my plan was getting the D60, D60 steering arm, spring pads for on top of leaf springs, 14BFF and the new 56" rear springs. the truck it would go into has a D44, 14BFF, a 4" suspension lift, 52" rear springs and 4" blocks . The plan was to swap the one tons in and possibly do a shackle flip with the 56" springs. I see a lot of shackle flips advertised for 1/2 and 3/4s only? would this setup still be an option? thanks everyone
