Oil pressure sender
Timmy adkins
Hinton
Tim
I cut the oil pressure sender connector out of my harness because I thought the gauge on my 79 c10 was mechanical. Thought I didn’t need it. Low and behold, it’s wired! Now I have to wire a new up. To be honest, I’d prefer the oil pressure sender to be out of the harness anyways because it wires into the bulkhead on the truck and if I ever want to remove the harness I can just leave the connector there.
The pressure switch is not wired into the pcm.
5.3’s require a 100psi sender. Anybody have experience wiring a stand-alone oil pressure sender?
Poppy 87
Bloomingdale GA
R10 Silverado
What engine are you using? What oil pressure gauge are you going to use?
Sent from my XT1254 using Tapatalk
Camar068
10 yrs Air Force
I'm using the autometer adapter and the original engines oil sender. My gauge only goes up to 60 psi, dunno why you would need a 100 psi sender, especially since your sending to an old gauge (assuming).
Timmy adkins
Hinton
Tim
A 5.3 engine out of a 2000 Silverado. And I’m running the factory mechanical gauge in the 79 c10
Timmy adkins
Hinton
Tim
Ahhh. So I can use the factory sender from the 79 engine (with the adapter)? I’m running factory gauges from the 79
Poppy 87
Bloomingdale GA
R10 Silverado
Perhaps someone can correct me, but I don't believe that the squares had a "mechanical" oil pressure gauge. Thought it was either electrical gauge or an oil warning light that is also electric.
Timmy adkins
Hinton
Tim
I think you’re right. Or at least what I’m seeing. There is a tan wire coming out of the bulkhead into the engine bay
Turbo4whl
Downingtown, PA
Wayne
My '74 K5 with the factory tachometer option, has a mechanical oil pressure gauge.
Turbo4whl
Downingtown, PA
Wayne
@Timmy adkins
Mechanical oil pressure gauges use a thin steel tube to run the oil pressure right to the gauge. No sender needed.
Camar068
10 yrs Air Force
yup. An expensive adapter (~$15-20). Might could find one locally for $5 with a little research on the block thread size/pitch.
idahovette
Weiser Idaho
Perry
K20-K10
My 75 K20 350 has a mechanical gage. Musta changed in 77-78 to electric?
TubeTruck
East TN
Denis
Suburban K10
LQ9
My '75 K15 also has a mechanical gauge
Timmy adkins
Hinton
Tim
Mine is a tan wire coming out of the bulkhead into the engine bay. And the water temp is even electrical
clendon1
Polk City FL
Butch
c10 stepside
468 BB
My 76 c10 has a factory mechanical oil pressure gauge.
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
My 77 has a mechanical oil pressure gauge. Used auto meter adapter in the factory 5.3 oil pressure sending unit location.
sszcam
