NP208 Transfer Case Rebuild You Tube Video
Part 1 Removal
Part 2 Teardown
Part 3 Reassembly
Kurnacopia
Tucson, AZ
Scottsdale
I watched all three of these videos. They were outstanding. I now feel I could actually attempt a 208 rebuild. I'm not saying I would be good at it....just willing to try it :)
Thanks for the videos!
I bet you'd do just fine. Just take pics at different steps as you take it apart. This way when you're going back together if you get hung up, then you have your pics to look back on as how something was before you took it apart. I do that and it's rare I need to look back on the pics, but it's that one time when I'll get hung up with something like, did this go on first, or does this go this way or that way? Simply look back at my pics and answer my won question. I usually feel good enough to tear into something, but videos like this give the confidence I need to know I can handle it and to go for it.
Kurnacopia
Tucson, AZ
Scottsdale
I would attempt this, but what I worry about is my lack of knowledge about the parts and their status of wear and condition. I could miss something that is critical and think its normal because I've never seen it. BUT....Id still love to try.
i
In most cases, the worn parts are obvious. Mainly things like bearings and thrust washers is what you'd want to check for wear. End play measurements will usually confirm you have things correct. I think the biggest thing to worry about in a Tcase, is measuring the chain in the case. If it's still good, it's good. If it's not or marginal replace it. Once that chain gets to loose from stretching, it starts slapping the interior of case til it wears a hole in the case, then it's junk and not even rebuildable. The chain is the most expensive part of the rebuild.
88chevy
