77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
So a few weeks ago I was testing my new tires. Drove up and over a pass. 4wd worked fine. Put it in 2wd and drove down the 10 mile dirt road and then got on the highway. Probably 10 miles down the highway while cruising at 60 mph there was a sudden bang/clunk noise and I saw my transfer case level jump. Then all was quiet and "normal". I wiggled the transfer case lever to make sure it was in the 2wd position. It was.
So today I try to use 4wd and nothing. Tried repeatedly to get it into 4wd hi and even 4wd low. Nothing. Always 2wd.
And I do not have hubs anymore. Had problems with them last year and removed them and put the stock full time 4 slugs back in.
So- what happened? Truck still works and drives fine in 2wd.
Since I've owned the truck 4wd hi always worked fine. However it used to pop out of 4wd low when under load. Usually made a bad noise when popping out.
So is this just the stupid stock transfer case lever issue? Or did something break inside?
Transfer cases aren't my thing. I just know many don't like the chain in it, and that if they have the part time kit then the "shaft kit" should have been used. I have no idea what kit was installed on mine.
