1987 GMC Jimmy
Automobile Hoarder
- Jan 23, 2016
- Mississippi
- Jesse
- V1500 Jimmy
What brand did you order and from where?
Cuba, good to know about the Rockauto discount. Just checked ECM fuse as suggested and it is good. However you said ECM A and B fuse and I can only find one 10amp fuse labeled ECM/IGN located under the steering column in the fuse panel. Can't find any other fuse panel under the hood except a couple of inline fuses on the passenger side firewall under a cover. I also looked in the owners manual and did not find any others referenced. I did find one labeled INJ A that supplies the throttle injectors but it is good as well. As a matter of fact I had my test light handy and they were open back fuses so I tested all of the fuses in the panel while I was in there. Y'all keep suggesting and I'll keep trying! Thanks fellows!Next time you should try Rockauto.com since you had to order it anyway. There's usually a 5% discount on parts through here as well. Not including shipping.
Thanks Cuba. Looks like Dave and I are fighting the same battle right now! I will keep a watch on his post and also perform the coil test that you wrote about there.
Will do and thanks again for the great advice!Whatever ends up being good after all (pickup coil or ICM), save it as a spare. My money is still on the ignition module. I got a new Delco module last year that lasted for three seconds and was dead. The replacement has been going strong for almost a year now.
Thanks Dave! I got the pickup running as well after replacing the distributor. It had to be the pick up coil in mine also because the 1st icm I installed tested fine at the parts house on 5 different tests. I guess the lesson learned here is that if you have no fuel and no spark with a rusty and corroded distributor, go ahead and replace the distributor before you waste a lot of time and money. Thanks for the help everyone!Yeah, we sure were (mine's running now)!! I would bet money it's the pickup coil - new distributor should solve it. Mine was basically disintegrated underneath that copper looking cap. Every time I touch it more dust and pieces fall out. I've read elsewhere that TBI distributors are kind of known for this problem. Older HEI distributors (carb) were known for module failures, but I don't think a module failure in TBI would account for lack of both fuel and spark - only spark. Good luck, let us know how it works out.
