"New" motor- what to go through?
scottyknows50
Ames, IA
Scott
Tomorrow I am going to look at a '77 parts truck for my '79 K10. Truck comes with a running 383 stroker that I would like to use to replace my 350 eventually. Anyone have a list I can use to check through it? Or do I just get a re-ring or rebuild kit from Summit, do that, and call it good? This will be the first motor I've pulled, but I have plenty of time and tools and am not in a rush. Thanks.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Can you start the '77 truck and hear it run before you remove it? If so you can then do a compression check on it. Also when you start it watch the exhaust pipes to see if it smokes on start up. If it smokes then the valve guides are probably worn. Could then let it run a bit to warm up, then hold it at a pretty high idle (2500-3000) then let off on the gas. If it starts smoking a lot that can be the rings.
How is the color of the engine oil? If it looks tan and "creamy" that can mean a bad head gasket or a cracked head (antifreeze is mixing with the oil).
scottyknows50
Ames, IA
Scott
Going to look at 2:00- I will check those things when I get there, thanks.
scottyknows50
Ames, IA
Scott
Noticed no smoking, idled well. Started very easily. Holley carb and Edelbrock intake. Looked like the oil pan may need a new gasket- everything else seemed pretty clean. Anyone have any advice on what to look at when I get the engine out and on a stand?
Thanks.
mjek421
