What is minimum vacuum needed at idle to run vacuum booster brake set up
sqhead
usa
Cheyenne
custom k10
I’m looking at a 383 stroker that has 14.5” of vacuum at idle. I’d like to stay with the vacuum booster but thinking I may need to get a hydro boost. What brake system are you running with 383 stroker or similar with that range of vacuum? Or has anyone tried the vacuum assist pumps?
sqhead
usa
Cheyenne
custom k10
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
It's a manual brake system converted to power. Original master cylinder still. And no vac reservoir but not much stop and go time on it.
Itali83
Maine
Ben
K10, 'burban C10, Jimmy
My 350 with a cam has 15 at idle in neutral and 12 in gear. No problems with vacuum and assist braking. Been running this truck 15 years that way. No reservoir just stock set up. You’ll be fine.
Ben
Rustisbest
Athens, TN
Mine is around 11 in gear with a reservoir. No issues.
My camaro had a reservoir. 14lbs you won't even need a reservoir.
Don-T
Vermont
Don
My K10 has a 383 that pulls 14” of vacuum at idle. It has vacuum power brakes and they work fiine.
I've got a pretty rowdy cam in mine, never tested vacuum but I know it's toward the bottom of the scale at Idle. The power brakes work just fine.
1987R10Man
