New build wont stay running
Layne02
Ga
Jeff
R1500
Hi, just rebuilt the 305 in my 87 Gmc Sierra. Turns over but won't fire til I spray starter fluid in, then dies after few seconds. Now I know fuel pump is working , watched it squirt fuel, but the thing I am not sure about is how old the gas is in the tank, could be 1-2 years. (long story). I took fuel line off under truck and drained what seemed to be most of the gas out, put in new gas but same thing. So could it still be old gas in there or am I missing something else? Thanks
rich weyand
Bloomington Indiana
Rich
A common error is to stab the distributor 180* out.
Did you check to see which TDC you had when you put it in?
Layne02
Ga
Jeff
R1500
Yea, pretty sure its right, it fires right up when you pit starter fluid or even a little fresh gas in intake. I was wondering about the TPS, I replaced it but just wondering if I got the arm on wrong side
Layne02
Ga
Jeff
R1500
Oh, one other thing, sounds like I have a vacuum leak somewhere but cant keeps it running long enuff to find it, would that cause it to die out?
Driver4r
Nebraska
Trevor
k10,c20
Few things to do, if you think you have a vacume leak, plug off all external lines, just unhook them from the TB, except for the MAP. Then, check for injector pulse. you can use a test light for this, or a NOID light. If you have pulse, the ECU is triggering.
Question, where is it "squirting fuel"? out the line disconnected, or out the injectors?
Layne02
Ga
Jeff
R1500
To update a little, i retarded timing a little and got it to start by putting a little fresh gas in tb. It ran fairly well and sat at idle til I shut it off instead of stalling out.
The gas is squirting from injectors properly.
It still will not start without putting fresh gas in tb first.
Could it just be that I still have some bad gas in tank that is keeping it from firing ?
The ses light stays on but I cant get a code using paperclip jumper, just keeps flashing 12.
87ScottW
