Need help. Nothing works
2burbfamily
Las Vegas
Greg
It all started with a leaking fuel line. Replaced that with a beautiful custom made piece. While it was taken apart we did cap, rotor, wires, plugs. Ran great. Started by drive home, but a bump on the freeway and it cut out. Coasted to the side of the road and towed home. Then changed coil, sending unit, fuel pump and filter and fuel relay. It cranks and wont start. I'm lost. Any help would be very very much appreciated. It's my daily and I don't want to let it go
86suburbanNJ609
South Jersey
Aaron
Suburban
Its sounds like definitely something electrical. Double check everything fuses grounds and whatever you touched while working on it.
78C10BigTen
pennsylvannia
C10 BIG TEN
Id start simple, check that your getting spark and fuel first. Sounds stupid but its usually something stupid. If you have no spark id look to the pickup in the distributor. I had one in a car take a crap on me while flyin down the highway in the passing lane at 90mph. Car just shut off, same situation coasting off the highway and would only crank. It was a cheap and easy fix once i found the issue.
2burbfamily
Las Vegas
Greg
I dont hear the fuel pump priming but I told myself it cant be a bad part. That tank was a bitch
Jppr26
Deer island
V20 custom deluxe
Use the red wire coming off your pump relay harness your ignition must be off that wire is a test/prime wire to see if your pump works
Camar068
10 yrs Air Force
Check how loose your connectors are that plug into the cap. Mine fell off and had to pull over. Fixed it with a crimp on blade connector.
Then a week later I had the same symptom but connector was tight. It is my daily driver so I paid $75 for a tow back to the house 3 miles away and it turned out to be something with the distributor.
If you decide you need a distributor, you might check out Skip White. Can't beat $50'ish for a distributor w/cap,rotor, and high output coil. They ship fast as well. Search "skip white" here in the forums.
https://www.skipwhiteperformance.com/catalog/category/distributors/chevy-8cyl-dist_7298/
Jppr26
Deer island
V20 custom deluxe
I know exactly what it is now. If you look at the picture you can find it.
Jppr26
Deer island
V20 custom deluxe
Battery ain’t hooked up. Sorry couldn’t help myself
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I’m in the same boat. Driving down the road the other day and boom. Nothing. I would have tested fuel pressure and tested the coil before replacing all that stuff unless you were planning to anyway. I won’t get into my predicament here, but my initial problem was a burned cheapie ignition control module that the PO put in there. Take it out and take it to Autozone and have it tested. Like someone mentioned above, check for fuel (injector spray when cranking) and spark (get a spark plug that you have laying around, ground it, and make sure you have spark and that it’s snappy and white).
73c20jim
Tombstone, AZ
2x
We probably won't hear back from @2burbfamily as to what fixed his so no sense in putting in my .02 on that one. What did fix yours @1987 GMC Jimmy ??? Was it the ICM???
Obviously it is, It CRANKS but won't start. There are such things as dual posted batteries with post top and side posts.
mmeade
