Need help identifying t-case and tranny
Wildjoe330
Right Now
wildjoe330
Itbp
Not a common combination, I can't recaĺl if there was a 205 with a 27 spline input. I think I've heard of them showing up behind a th350, but I'm not positve. In any event, if you can't find a way to use factory parts to mate them, it's apt to get expensive.
I got lucky picked up a 700r (core to me) and a figure 8 np205 with the adaptor and the collar that should be 27 out and 10 into the 205. I still l need shift levers and drivelines.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Twin stick it front wheel digs are way cool and you can run 2 wheel low.
jtridgley79
US
jason
v10 suburban, k10 pickup
both 350
Gotta grind shift rails to do front wheel Signor off-road design has new of them too. They also have a short output shaft for the 700r also
Sent from my HTCD160LVWPP using Tapatalk
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I was gonna run a D20 in my truck but I didn't like the front shaft angle but I had a twin stick set up for that. I think there is a pic in my build thread of it hanging on the back of my th400. Now I have 2 D20s collecting dust.
Wildjoe330
Right Now
wildjoe330
Itbp
Gotta grind shift rails??? I'm not sure what to do on that one?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
That's if you would twin stick it but I'm sure there are ways around that. 1 stick for hi/lo and one for front/rear and 4wd
jtridgley79
US
jason
both 350
The two rods that slide in and out,one is front the other is rear. The front won't move if you don't move the one for the rear. You have to take them out and grind them open,not sure where off hand, to be able to put rear in neutral and engage front to do front end digs
Wildjoe330
Right Now
wildjoe330
Itbp
205 did come behind th350 but you will need a spacer that you can get from off-road design to put it behind 700r
My 700r and np205 (Came with spacer and Collar) were mated up at one time in a small truck muck up, and it made me wonder if the 27 output shaft on it to the 10 input shaft 205 was too long and needed to be shortened or spacered?
Spacered ha lol.
Wildjoe330
Right Now
wildjoe330
Itbp
Isn't that one for front one for rear.
Wildjoe330
Right Now
wildjoe330
Itbp
Your not bad, ha
Wildjoe330
Right Now
wildjoe330
Itbp
jtridgley79
US
jason
both 350
Would have to be an older pic, I have been following your build and the last pics I saw were the bedsides
tnahaus
