need help aftermarket wiring harness
jsilver36
WI
jonah
What is the best aftermarket wiring harness that you can get for the money that comes with everything from head and tail light wiring to the fuse box....I want it all...all the wires you need for a Chevy k10 1986 350 carb 4x4
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
I'm going to be doing the same for my 73 and I'm pretty sure that I'll be getting mine from American Autowire. The other place is Painless.
yevgenievich
Viktor
sad
very sad
less sad
I have used kwik wire before. It is universal harness but everything is labeled and quility is good
yevgenievich
Viktor
sad
very sad
less sad
With any universal harness you would have to reuse some of the old connectors, but otherwise it would work. There is a lot of soldering involved to properly install universal harness. Other option is to buy factory style that would be simple plug in.
Here is one for conventional mount location, but otherwise the same from kwik wire.
http://kwikwire.com/wire-harnesses/...22-circuit-second-generation-with-ground-kit/
jsilver36
WI
jonah
where can I get the cheapest stock wiring harness
highdesertrange
kalifornia
mike
k30
what is the best? Painless
what is the cheapest? Tijuana auto wiring.
highdesertranger
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
I will say that I ended up ordering my kit from American Autowire on Tuesday, got it on Wednesday, and just by looking at it I'm VERY impressed. Installation will begin within the week, but it looks very good. Got mine from Summit and it was $70 less than from AAW website.
gmachinz
Harnessworx Inc
Iowa
Jabin
If anybody is still looking for OEM GM style harnesses, drop me a line-I offer production style replacement harnesses as well as late model upgrade features not found with anybody else. The problem with having to re-use your existing connectors is that most of the time their toast anyway....if not missing to begin with. Plus you don't get the various looming, harness wrap, rosebud clips, breakouts, grounding rings, etc. There are a lot of "little" things left out of these types of harness "kits".
That is going to be real soon. What do you charge?
gmachinz
Harnessworx Inc
Iowa
Jabin
Well, here is a list so far:
Engine harness
Front lighting harness
Rear lighting harness
Dual tank harness
Power window/lock/mirror harness(es)
AC climate control harness
Besides those basics, I can incorporate auto down and/or up for the Windows, delay off for the headlights, relay upgrade for all, LSx dual tank conversion harness options, etc.
It's easier to work with people one on one to determine the best possible routes.
Don't need dual tank. Do like the auto up and down. What's the basic price for that?
Sent from my SM-N910V using Tapatalk
Ls85c10man
