Need a complete column shift linkage
circuitguy
Elk Grove, CA
BIG-C
GMC 1/2 ton Stepside
Need a complete column shift linkage for my 87 GMC R10 truck. Has the 700r4 trans if that helps. Should look like the pic below, for the truck shown.
I've got one, but I don't know what the pieces are in the top middle of the pic.
No.....I have the frame bracket, and the spring, poly bushings and shift rod, I'm talking about the little pieces to the left. It looks like a little bolt and nuts. I don't know what that is.
robert8096
Goose Creek SC
Robert
Ahh I see now. I was looking at that on my phone when I responded the first time. Now I am looking at it on a laptop and see what you are saying. I have never seen that little bolt and nuts on a steering linkage from our trucks.
:sorry:
@Mr Clean: It is little bolts and nuts. :rolleyes: :crazy:
circuitguy
Elk Grove, CA
BIG-C
The small hardware I can get here, its the just of it that I need. Need all the rods and the pivot that connects the rods together. Don't need the bolts, spring or the frame bracket.
I've got a couple of them. I'm sure you'll have it powder coated, pay for the ride, and I'll give you the linkage.
circuitguy
Elk Grove, CA
BIG-C
You da man!
PM me your number so I can your info and get you paid.
here is the linkage,
I'll need a pic of the dimmer rod, I don't remember what I sent to 89.
circuitguy
Elk Grove, CA
BIG-C
Linkage looks right, can you verify its correct? As for the dimmer rod, wish I had one to take a pic of. I know the dimmer rod is the same from 85 to 87 truck and 85 to 91 suburban. Must be from a tilt column.
derek87
