Moog adjusting sleeve NIGHTMARE!!!
thaifighter
Banned
chilliwack british columbia
brian
k20custom deluxe 16.5 rims
350 sm465/np208
Having problems installing these MOOG joints...
It ain't just Moog, they all are CRAP. The Moogs are just less crap. I've always tightened the sleeve by feel, but it's probably about 25-30 lbs.
thaifighter
Banned
brian
350 sm465/np208
When I installed moog, in the same truck 15 or more years ago I had no problems at all and they still were in not to bad shape a little slop in the top joint on both sides so an upgrade was in order, .... of course it wasnt a daily driver more for rv and ocasional work purposes..... problem is I cant even achieve any torque on the sleeve.
before i try to replace the suspect joint I think Im going to try installing the sleeve just below the yoke with the lower joint loose,
torque the upper nut then the lower any thoughts........
8T6K5
AZ
L98 350 TPI
and.... #2 if there is no remedy to let you know to STAY AWAY FROM MOOG ball joints!!:025:
Did upper/lower MOOG on mine 2 weeks ago. No problems.
Man that sucks. I never ran into that problem.
Beatdown Z
Newark, DE
What are you using to measure the pull on the knuckle. I just went with the instructions and let er eat!
thaifighter
Banned
brian
350 sm465/np208
Ok ..... so I ordered the joints from rock auto so there was going to be no easy swapping the suspect part with a new one ,yesterday I was pretty pissed and I did go buy a skf joint thinking I was going to swap it over
Today having slept on it and cooled down a little I thought I would try different variations of torqueing like leaving the lower loose and doing the top end first
what I ended up living with was
.....torque the bottom to spec 80ftlbs
.....finger tighten the sleeve to just a few threads below the yoke
.....Finally tighten the upper to about 75-80 lbs spec being 100
and even that was to tight probably about 30-35 lbs on the old
"spring loaded fish weighing scale"
I think it will be ok.... of couse it will loosen up in time but I'm definately going to be keeping a close eye on things for a while and can see me having to retourque that upper nut down some more thankfully I dont run a wide tire because I'm sure the steering pump would be pushed beyond its limmits if I did
Now I am doing a restore so it wont be on the road for a few more weeks so I'll update this thread after a few hundred miles or so .
johnalen76
