Mechanical to electric cooling fan
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
Been wanting to convert for a while and was not sure how I wanted to make this happen. Thinking of using current plastic stock shroud, mounting electric fan inside. Possibly fabricating mounting brackets to the inside front nearest to radiator. Has anyone done this? If so, pics would help.
Also, I have found a 16" fan. Shroud inside diameter is 21". Is there a minimum cfm fan needed to keep it cool?
TIA
Someone here has done it. Chrysler did it too, but they used it in conjunction with a mechanical fan.
Personally though, I prefer dual fan setups that are easy to find and they are simple to mount up too. Why bother with a single fan?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
TIA
If it's a BB it will need more cooling power.
Lots of fails around here with E fans. I mean overheating.
And many junk fans out there too. The best are Spal.
Best way to rate a fan is by the amps used to run it. Yes more is better! Don't trust the cfm ratings, there are too many variables and manufactures
will always use the best results.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
I'm running a single T-Bird fan in my truck, keeps it quite cool. It has never run hot on me.
Did you fit it to the original shroud?
My thought was just that dual fan setups are so easy to find and mount, it makes more sense to me to just skip the single and run the duals. I'm sure a big single can flow enough air though, no arguments from me.
I just realized your radiator is much wider too, right? The average dual fan setup probably isn't wide enough then.
bluex
Spartanburg SC
C15
I used a 2002 Jeep Grand Cherokee fan. Works really good for me, no problems keeping it cool. Bolted it right into the stock shroud.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
Do you know the fan diameter? The single fan keeps your SBC cool enough, I'm guessing. Just not sure what size fan to go with. I could probably make brackets in my existing shroud. Any and all info I can get is helpful for me to decide. I would like to only use one fan.
436'd skylark
VT
Joe
2500HD
Durajunk
The best bang for the buck in electric fans is the late model crown vic fan. Put a Google study out on it. It's available in the aftermarket and moves a ton of cfm. those boys in blue don't like to be warm....
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
What year models apply to late model? Present to past 10 years or what? Trying to get all info I can.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Im currently making a dual 14" shroud for my truck. I've got the smaller 350 radiator, not the BB one. We'll have to see how those two fans do, think the each pulled around 10-15 amps too.
Using Pro Comp 14" (Curved blade) fans and a flex-a-lite controller with the pipe threaded sensor, not the temperature probe for the radiator fins.
bluex
Spartanburg SC
C15
It's 18-19" I guess? A lot of people use this fan because it's easy to fit it in the stock shroud. I have a 3 row radiator, a high flow water pump and 190 T-stat. It runs around 195-200 running down the highway. The motor is .060 over and I've never had a problem keeping it cool. I had a lower degree thermostat for a while but it put out zero heat in the winter so I upped it the last time I had it apart.
Billy
Dalton Ga
Billy
This is what I did. The cop cars have the best single fans
Tazdar
