Apr 26, 2012 #1 G GOBR Full Access Member Joined Jan 24, 2012 Posts 327 Reaction score 2 Location Memphis First Name David Truck Year 1987 Truck Model R10 Engine Size 355 When setting the timing in a vehicle equipped with an auto trans you adjust timing and carb with the vehicle in gear correct? Not park or neutral?
Apr 26, 2012 #2 G GreaseDog Full Access Member Joined Aug 8, 2010 Posts 1,189 Reaction score 33 Location Elkhart, IN First Name Jeremy Truck Year 1977 K20 Truck Model 1980 K2500 Engine Size 350 Uh... No. you adjust out at a warm idle, in park, with the advance mechanism disabled (vac line unplugged, electronic advance disconnected)
Apr 26, 2012 #3 G GOBR Full Access Member Joined Jan 24, 2012 Posts 327 Reaction score 2 Location Memphis First Name David Truck Year 1987 Truck Model R10 Engine Size 355 Ok. I saw on the accel video where they chocked the wheels and set everything while the car was in gear. Just double checking.
