Manual swap questions
Chakoman
Tygh Valley, OR
Harley
Suburban v1500
I am putting a sm465/205 into my 91 suburban. I just have a couple questions i couldn't find the answers to. My pedal assembly is from a 77. Do i need to change the brake switch and the switch on the clutch pedal to ones from 1991 suburban with a manual? Can i use my existing steering column? Thanks in advance for the help.
eskimomann209
Modesto
Marcus
Not sure about the NSS. I’d imagine you’d need one and any one will work. Yes your brake switch is fine. the biggest problem I see is your speedometer. The np205 is 99.9 percent of the time mechanical speedometer drive. The 91 suburban uses a VSS.
In fact that driver drop 241 you have is worth about 4-600 bucks depending on buyer and market... having said that I’ll offer you 100 bucks.
Your steering column should work fine. Pull the pin and remove the shifter for looks ... there are a lot of floor shift cars you could get a sleeker looking one from however... odds are your burb has OD.
You’re going to lose that with the 465. You’d be better off looking for the nv4500 I have seen like 4 in Oregon.
Chakoman
Tygh Valley, OR
Harley
Suburban v1500
Thank you for the reply. Ive already got the 465/205 combo so ill live with it. Gonna be used mostly off road. Pulling my first steering column was quite intimidating. Lots of plugs. Just got to figure out what to wire the clutch safety switch to. Thanks again for your help.
Andrew45
