Doppleganger
- May 24, 2019
- OH-MI: Just like it sounds
- Chris
- K20
My K20 needs upgraded - only deciding factor now is cost. I think to rebuild an LS or a Vortec either one is probably a wash cost wise, but the 'little' things are what add up fast. I dont want to drop anything in without really checking it out / opening it up. I had a 77k motor once that I dont think the oil had been changed twice. Looked immaculate on the outside - inside, not so much. I remember using Gunk Flush in it and when we drained it out it looked like we were giving the car an enema - large blobs of sludge. Stuff like that. Also had a 113k motor that burned a qt every 100 miles.....when we opened it up, the cylinder walls looked like chrome - my tech buddy guessed someone used an additive or something and the rings never seated properly. Dunno.
The 6.0 LS I found has 142k on it. I suppose it would be ok as-is.....but what about the coil packs? Or the harnesses? Or the ECU that will need flashed? These are the expenses I know can blindside a project and leave me with the GDP of a small country tied up in a truck thats not running. Bad juju.
Also found a 98 Vortec 5.7 with 150k. Could keep it carb'd for the time being til I sell a kidney or something to buy a TBI setup.
My Plan C is to source a reman set of Vortec heads, add an Edlebrock performer intake, maybe a better cam and use the stock 350 as-is.
Just thinking out loud - wondering what you fellas have encountered with your own swaps / upgrades. I searched and read quite a bit but $$$ figures aren't mentioned as much. It also needs totally rewired badly so alot of what happens under the hood will affect that as well.
Thanks in advance.
Thanks in advance.
