Lower door carpet
If it was you, how would you go about making that happen?
A good cleaning to start with. If the cardboard backing is warped from water damage, dunk it in a tub of warm water, then lay it out to dry with heavy items weighting it down in the right areas. Spray adhesive to reattach the carpet to the cardboard. Then a couple light coats of spray dye. After the first coat dries, brush the carpet with a stiff nylon brush, then apply the second coat.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Well thanks to Jesse I have a set now. I just picked up a really nice set of blue ones just for the chrome part. If anyone needs a blue set minus the shiny part hit me up.
echo7bravo
Alabama
Adam
K-10 stepside
350/Th400, 4.56 with 35" BFG MT
I pulled my wrecked carpeted pieces off and used the backer board for a template on some hard board (peg board without the holes). I then recovered with some black Toyota trunk carpet. I also cut holes for my plastic door vents which i painted black to match. And last but not least I cut holes in my new backer board and installed the plastic fasteners that just push in. (Had to drill new holes, but now visible screw heads any more.
Long drawn out story short....I chose not to use the silver strips but still have them in the garage if anyone wants them. I can take photos if someone does want them.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Well let’s see them...not the strips the door thingys.
echo7bravo
Alabama
Adam
K-10 stepside
I will post up some photos. Have to give me a couple days. I'm on my 12 on 12 off night rotation.
echo7bravo
Alabama
Adam
K-10 stepside
Ewww yuck
Story of my life. Feel like I spend half my life at work. Then when I get my off days, I end up sleeping away the first one just trying to let my body catch up.
What even sucks more is my partner in crime works days and we can only get up with each other every other weekend. I need to drop both my fuel tanks to fix the sending units and to weld under my seat in order to reinstall my seat. Kinda hard to drop fuel tanks by your self.
johnalen76
