Looking for opinions on Lowering Kits
Vschmole
Decatur Tx
Chevy
What lowering kit rides the best? I am looking at maybe a 4/6??? Just thinking about dropping a little lower and using the proper parts. It’s kinda rigged right now.
Welcome to GMSB !!! Since you're asking about lowering kits, I've updated the title to your thread and moved it to the Lowered Suspension section from Introduction.
Should be some opinions here shortly.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
McGaughy drop spindles..2 inch paired with 2 inch drop coils for the front...flip kit for the rear along with shock extensions so you can still keep the factory length shocks, unless you want to upgrade to drop shocks (much better ride).
I had Mcgaughys setup in the front until I decided to jump into the deep end of the pool and completely bag the truck.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
My opinion is I look for trucks like this all the time to replace the rusted out bodies on 4x4s.
Vschmole
Decatur Tx
Chevy
Thanks, that’s kinda what I was looking at myself. When going that route with the flip kit.... would I still need to be doing the c notch?
smoothandlow84
Steve
Some people who have installed the rear flip kit did not install a mini notch. I did because I wanted some extra clearance for the rear axle.
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Does anyone have any opinions on shackles? I have a stock height 78 on 31s and have been considering grabbing some 2 inch lowering shackles to level it out
smoothandlow84
Steve
If you install drop shackles, you may have to notch the bed reinforcement rails for clearance. I had to before my truck was bagged.
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Funny thing is, my bed is already notched. That and the new stock front coil springs makes me thing this thing was lowered at some point, but the po stole his drop springs and shackles before selling it
rwjjr
East TN
Wayne
383 Stroker
You don't need a "kit"
This truck I used the following:
3" belltech spindles (on sale at Jegs for $280)
New Moog Big Block coils with bottom coil cut ($75 amazon )
KYB front shocks ($38 Ebay)
Rear flip kit ($40 Ebay)
Rear shock extenders ($45 Ebay)
Less than $500 for quality parts and I will put the ride and handling up against any lowered C10 in the country!
86Peter454
Missouri
C10 Scottsdale
whats the reason for putting in the big block springs?
you have a link to the springs?
rwjjr
East TN
Wayne
383 Stroker
Cheaper and better ride than drop coils, with the more heavy duty springs you get a better spring rate after cutting. I have a dropped 83 with the same setup, except I cut the "factory" coils. The one with big block coils rides much better. Use Moog 6454.
86Peter454
Missouri
C10 Scottsdale
thats cool. ill check them out. going to be dropping mine here pretty soon hopefully.
johnalen76
