Led light bar mount
Chevyturbo
Tx
Ariel
C25
Anybody know who or where I can find led light bar mounts ?
static_86
Ontario
Any luck finding mounts yet?
CaptainA
Iowa
Jonathon
K15
I have a 52" curved light bar with 50" mounts for a GM. I haven't put it on yet, but measuring and dry fitting, I think it will fit, if you remove the drip rails and mount it a little farther back from the windshield. I haven't tried it yet because I'm currently trying to get it running again, but when I do, I'll try. If it doesn't fit there, then I'm gonna mount it on the bumper. Since it has the three inch body lift, it fits perfectly between the bumper and lower grille.
87ChevyR10
Kansas
NA
NA
NA
I saw a ridiculous LED bar setup the other night. I literally thought someone was driving backwards. This truck used red LED's and had the bar mounted above the headlights. So it looked the the HL's were the reverse lamps and the LED bar was the third brake light. I definitely did a double or triple take. I am surprised the owner was running red LED's. I imagine running anything other than white up front is illegal.
87R10_Cruising
