Jumpy oil pressure gauge
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
Every once in a while the gauge will start bouncing around like it's an electrical thing. Most times it's steady and rock solid, then it will start getting jitters. Both under power and at idle. Is this a sign of a bad sending unit. Other than that all is well and the engine performance is solid, oil topped up. Will AT205 leak stopper create a problem in the sending unit? They say it wont, but could this cause a jumpy gauge? It's the only thing I can think of, all connections are good.
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
It works properly, just gets jumpy sometimes. Going to change the oil and see if the gauge still acts funny. I'll do the ground test on it. If it keeps it up I'll just swap out the sender.
KnuckleBuster
USA
Floyd
The sender on these trucks was prone to failure. I'm not much on throwing parts at a problem, but it's a pretty safe bet. Also, make sure the plug wires aren't routed to close to the sender wiring. Good lock!
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Mine has off and on given odd reading at different times because the spade connector not being tight on the terminal of the sender and it's wiggling. Should be a snug fit on the terminal.
WebMonkey
Missouri Ozarks
mine has gotten jumpy from time to time at higher revolutions.
flutters from 30psi to 60psi rather than 30 to 0 (low)
when i 'mess' with the wire at the sender, it usually goes away for a couple months.
the wire does find it's way near the plug wires/distributor.
good luck!
'monkey
AceHanlon
Halifax, PA
Logan
Mine would do that sometimes as well until I replaced the sensor. Reads better and doesn't jump around. I suppose it could also be the gauge itself given the age of the truck.
jp wessels
