Interior Lights, Head lights, Radio are not working
Suibeom
NJ
I believe I have a fusable link issue from what I have read so far. All of the fuses have tested out fine, I replaced the ones that were oxydized just in case.
The truck starts, fans work, wipers work, turn signals and brake likes are fine.
It is just the interior lights, headlights, horn and radio that seem to be out.
I did replace the alternator recently and i expect that is when it happened. I don't drive it at night or use the radio since the speakers were blow out :D
I had voltage at this connector so I think i am good, i did not check by the starter yet.
This is the one I am wondering about, I am going to throw a multimeter on this and see if it has continuity and voltage. I will post more once I get a few more tests in.
Suibeom
NJ
I checked the two cables coming out from the bottom of the fusible link and they both have the same voltage as my battery. here are a few more pictures of the fuse box.
Mystery item just hanging out near the firewall.
At least it is wrapped in tape?
This guy was just fell out when I removed the vent tube for the driver side vent.
The fuse box.
I am going to keep digging around, to se what I can find.
Suibeom
NJ
So there are two red wires that feed back from the constant (I believe) back through the firewall. I found these two schematics on the web.
One of them had voltage, while the other did not. I suspected that it has to be the feed from down near the starter. When I looked It seems one of the lines is broken. Fixing it looks like it is going to be a PITA.
Of course, it looks like I hit an oil well when I was under there, I guess I will be taking care of that as well.
  • 1980 wrg diag 01.pdf
  • 1980 wrg diag 02.pdf
Suibeom
NJ
So it was the fusable link down by the starter, as I thought it was a PITA.
PhotonFanatic
Arlen, TX
Wilhelm
Do you happen to have a picture of this fusible link, or know where I might see one? I'm having a similar problem and I'd like to check out my fusible links. I recently replaced my starter, so I could be having the same issue as you did.
Suibeom
NJ
If you look at the last photo that is the broken wire to the link. It's the best I could do.
PhotonFanatic
Arlen, TX
Wilhelm
I thought if I actually used Donald Trump, I’d get kicked off the forum!
Hmm... Maybe not this forum. Of course they may have a thing about any political talk. Most forums do. Nothing good ever comes of it lol
C30vet
