Installed lift kit but front lower
81woody
Brent
I installed a 4" rough country lift kit all leafs but my front is lower the the back.... It's a 81 k10
What do you guys think it could be?!
Was thinking of doing 1.5 shackle lift to even it out.....
nvrenuf
Mobile, Al.
Have you measured how much difference there is front vs rear?
Fyi, a 1.5" shackle lift will only net you .75" lift. In order to acheive 1.5" of lift from a shackle it will need to be 3" longer than stock which is too long and will snowball into other problems (caster angle wrong, possible death wobble, etc).
81woody
Brent
I measured from top of the tire to the top of fender well. (Don't know if that's the best measurement) but both are 12"..... But looking at the truck even sitting in it the front is lower..... Maybe body mounts wore out?
nvrenuf
Mobile, Al.
Measure to the body line, the fender wells are not even.
81woody
Brent
2" difference from top of tire to body line...
8T6K5
AZ
L98 350 TPI
ORD-DIY4X zero-rates....
Sent from my iPad using Tapatalk
81woody
Brent
Any body?!
muddyman184
Phila
steve
90 AND 82
K5,K20
Just like 8T6KS said OFFROAD DESIGN or DIY4X has the zero rate add a leafs go to their website and check it out
81woody
Brent
Muddyman184 thank you wasn't sure what he wrote lol
Olecuz
South ga
Will
K10 stepside
I would just put a smaller block in the rear.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Reread the original post he said its all spring no blocks to change out
Olecuz
South ga
Will
K10 stepside
Whoops... you could remove a leaf in the rear then
...if you ok eith that.
Swims350
Logan WV
none
have you drove it any to settle it down?
if not try it.
if so then add a leaf in front or remove some out back, or do add a leaf and longer shackles in front maybe.
I like that add a Zero Rate up front best !!! :waytogo:
Christian Nelson
Wisconsin
Christian
K15
What is wrong with a bit of rake anyways?
12turnda
