I cant get my new engine to run smooth. Seems untunable.
Big Ray
North Carolina
Ray
the kits are cheap. A decent mech should be able to do it at home. Might not be as purty, but should work fine.
The throttle shaft bushings are easy. Just take your time.
1STLS1
West Phoenix AZ
MIchael
The last time I rebuilt a quadrajet and needed shaft bushings, I believe I made my own kit with bushings I found at Tractor Supply and 2 standard sized drill bits. It wasn't that big of a deal or very expensive.
When chasing a vacuum leak that is next to impossible to locate, see if somebody local has a "emissions smoke machine" that can check your engine for you. This is the easiest way to determine bad lower intake manifold port gaskets. You can also make one reasonably cheap from videos on YT
Big Ray
North Carolina
Ray
All my interwebz buddies have that cool stuff. They're just spread all over the country!
1STLS1
West Phoenix AZ
MIchael
I saw one set up they used a cheap cigar, it's not rocket science but really the only way your going to find a leak like that
Camar068
10 yrs Air Force
between 3-5 hundred bucks. That's dipped, bushed, jetted and adjusted to your application, refinished and looking like new.
If I had to do it again, I'd send it off over getting a new carb or doing it myself. What I've seen to rebuild one perfectly, would be (to me) the same as learning how to weld or almost as bad as rebuilding a transmission lol.
nothing meant, just a skill/time/value thing.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Im not afraid of doing a rebuild myself, habe done light rebuilds before. Not too bad, i like that sorta thing. Will end up doing tha someday if i have the time..
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
They’re actually pretty cheap online. My BIL got one to find an evap leak on his Toyota. I help him with car stuff all the time so he gave it to me. I want to say it was under $100. Worked great.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
It's not the manifold, it runs great now with a new carb.
I read this on a different forum haven't had need so haven't tried it. Cap the intake put your shop vacuum exhaust hose in the tailpipe and pack a rag around it. Turn your shop vac on and start spraying everything with soapy water,just like looking for a tire leak.
Albrigap
South Dakota
Alan
Suburban
What is your vacuum reading?
That tells the tale.
Rusty Nail
Rusty
350sbc
Yes, ive moved it around, seems happiest by ear right there. Wants to die if you either direction. Can chek the timing when its reving high, but if you hold the coke butterfly down a little, you can get it to idle down 700-800 for a few seconds before it dies, and it looks like its still set to about 10-12° which is where i had it set when it was on the stand.
I put the engine in with a chain bolted to the back of the passnger side head and front of the drivers side head, and a safety strap around the pan, why?
Wants to die if you  what either direction?
Runs great with a new carb but still idles crazy?
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
If i turned the cap either direction. Advance or retard..
But no worries, it runs great now. Turned out to be a massive vacuum leak threw a super sloppy throttle shaft bushing on the Qjet i had on there..
jp wessels
