- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
This is not correct. The turn lights and brake lights are the same single bulb on each side. Two wires (yellow and green) to make both brake lights light up. If you turn on the the turn signals, then power is interrupted to that side when the brakes are applied.
Brown wire feeds all the tail lights and license light. Light green wire feeds both reverse lights.
Crap, you're right... although it is still probably a single wire issue since neither brake nor turn works on just the left side. That points to a problem with the yellow wire. The connector will be a round plug behind the bumper near the drivers side frame rail. That bundle runs all the way up the drivers frame rail, under the brake booster, and into the firewall connector.
