How Will My Square Body Look With XX Lift and XX Tires?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
6" Rough Country front springs
2" Rough Country add-a-leaf in back with Super Lift shackle flip with 52" springs.
2" body lift with Emergy Suspension poly body bushings and home built 2" bumper lift because it looks ***** with bumper gap
36/12.50-15 Super Swampers on 8" stock rallys
Had to lengthen the selector rod for the transfer case. Also the shackle flip does drive line angle correction but moves the rear axle forward a bit.
Front springs have a factory installed wedge block that angles the pinion up
Transfer case spacers were moved from the bottom of the cross member to between the frame and cross member to drop the tail down.
I wish there were more tire options in the 33x10.5. I only know of BF Goodrich All Terain Radials in a 33x10.50x15. I'd really like a 35x10.50. I want a taller tire, but I don't want all the width. I don't think people realize how bad tire width affects mpg and strain on the powertrain.
Ireland87
indiana
jacob
k10/v10
305 sbc
how high off the ground is the floor board of the cab of the truck with a 6inch lift with 37's or a 4inch lift with 35's. Trying to figure out what size lift i want to but on my 87 k10 shortbed
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
If this helps top of my bed is 64” wheel arches are 46” that 6” Suspension lift 2” body on 36s
SDJunkMan
Black Hills of South Dakota
Jeff
This thread is great, really helps visualize what a lift and tires will do to a truck.
I'm thinking I would like about 3-4 inches of suspension lift, and run 33's on my 78. What is the point where you have to start doing major driveline and steering changes? At 4" can you just do springs, shocks and a dropped steering arm, or are there other things you should change? My truck will spend most of it's time on the street, but I will do some off roading.
4 inch lift is a pretty good "jack of all trades" lift. Extended brake lines are something that would be good to add to your list. But other than that, a 4 inch lift is very simple. For a truck that you drive a lot, do yourself a favor and go with springs that are known to ride a little softer.
SDJunkMan
Jeff
I will probably be replacing the brake lines anyways, as I am adding the lift and cleaning up the underside of the truck. Any particular kits ride better than others?
Basically, the more they cost, the better they tend to ride. Tuff Country and BDS are on the top of the "not a log wagon" list. Unless you go with custom springs.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
4 link front and rear with King coil overs.....
SDJunkMan
Jeff
Bucket,
That sounds good. It probably won't be until spring before I get ready to do the lift kit, so I have some time to do some research. Heck, I don't even have the truck home yet!
sabbath2012
Idaho
corey
72 Chevy 49" irocks on 16.5 rim with 27" lift (7" Body and 20" springs No blocks) Rode like a tank
Left to right 83 K5 8" lift all suspension on 38" Toyos,
79 K5 16" lift (3 body, 13" suspension Custom springs, shackles and perches) on 44" TSL,
85 K5 8" lift (2 body and 6" suspension) on 38" baja claws
90s jeep on 33 i belive stock cut fenders (rubs)
83 K5 8" lift on 38.5 boggers,
79 K5 on 9" lift with 38.5 TSL
85 K5 with 6" lift lots of trimming and 44" TSL
77 K20
Montana
K20 5" lift
HT383 fuel injected
Does anyone have any pics of 315/75R16 tires on their truck? For summer time I'm thinking I will bump up a size to those.
Robert Samaniego
fabens tx
Robert
GMC
6"pro comp suspension lift . 6"inch front leaf springs and 4" leafs with blocks on rear. 3 inch body lift for a total of 9" lift. Riding on 38" Iroks 15inch wheels.
Robert Samaniego
fabens tx
Robert
GMC
12"Superlift suspension lift on 15"wheels and 38.5 MT tires.
Dan87r10
