How Will My Square Body Look With XX Lift and XX Tires?
Rusty Nail
Rusty
350sbc
Friggin beautiful truck !!! Look at the shine !!!
I might have an idea how that got so shiney. :shrug:
:manos:
That **** is lmao right there.
I be all like, lmao.
3 inch Rough Country on 32x11.50. Wrapped on a 15x10, they measure out 30.5.
87scotty
Central il
Andrew
V20
5.7 for now
7Ich 4 suspension blocks on rear 3 body on military 36 12.5 16.5
Big block comin soon and i got a truck ned camper so thinkin gettin rid of body and goin all spring
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
I'd go for a combination of a smaller body lift (~1" or so) to allow for that little bit of extra clearance and then go all spring. From there, run a set of ez rates if you really do need an extra inch after all is said and done.
87scotty
Central il
Andrew
V20
5.7 for now
i like a small gap between frame and bed thatd be nice easy to clean out underneath but i dont think lift springs will like the bed camper things heavy and stands 12ft in the air lol so she sways and that means the camper is only setting on a few points rather than the whole frame so im torn on what to do
i thought about a quick disconect bag setup but still pondering ideas spring shop said i should stay stock springs maybe just upgrade to 1 tons and keep the lift blocks but i dont want to lose height i like the stance my truck just has to many purposes
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
You could easily go all spring, would just depend upon what spring rate you get.
Do you know about how much the camper weighs?
Used to have one in my truck. Stock spring pack, but added leaves and a 1" block to make an 8-leaf spring pack. She sat level at that point with the camper full of gear (queen bed, stove, propane tanks, refrigerator, etc).
The taller lift with the camper will make her more prone to wandering due to the wind and high center of gravity, but we knew that already, eh?
I'd suggest majority, if not all, spring lift. Drop the body lift down to a 1" (bed is only supported on the frame in a few places anyway) to lower that center of gravity. From there, if you have sagging, either add a couple leaves to increase the spring pack rate or add bags.
With taller flexible springs, i'd recommend adding a ladder bar or two to stop any axle wrap you may have.
808 k10
hawaii
tom
6 inch pro comp with 33x12.50x15
CaptainA
Iowa
Jonathon
K15
What about 4 inch lift and 37s I would be using cut out fender flares I am also open to a body lift the highest is a 2 inch body lift.. How would that look.
I've got the four inch suspension with a three inch body. Plenty of room for flex, but I am considering 37's
4WDKC
Southern Florida
Kacy
Maybe this should be a stickie, and 33x12.50r15 front and 315/70r17 rear axle swap in prgress.
Craig 85
Nashville, TN
454/TH-400/NP205
1977 Chevy K5 Skyjacker full spring 6" lift. Dick Cepek 15/36R16.5 tires. Bush Wacker cut out flares.
1987 GMC K20 4" Rancho lift 33x12.5x16.5" tires
1979 GMC K15 4" Tuff Country EZ Ride lift. 33x12.5x16.5 tires.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
The shorty is so beautiful it hurts my eyes, if that makes sense. Maybe if it was in my driveway my eyeballs wouldn't ache so bad.
78C10BigTen
pennsylvannia
C10 BIG TEN
Here is my new 77 blazer I am in the process of putting together.
8 inch skyjacker , with 0 rates front and rear for 9 inches total
40/17-15 gateway gumbo monster mudder's on 15x14 bart wheels.
Thats AWESOME!!!!!! I love it
78C10BigTen
pennsylvannia
C10 BIG TEN
I don't think we have pics of that combo, but I don't think 2in lift would look bad at all with 31's. I'm with you though, I do intend to have 2 4x4 Squares. 1 is going to be very close to stock height and tire size. BF Goodrich does make a 33 x 10:50 tire that I intend to use on my 4x4 that I'll use more for street driving and bad weather. I don't want to hurt the mpg to bad, so keeping a narrower tire will help reduce road friction and drag, but yet give me a little more lift that I want. If I was to go with a 12.50 wide tire, I'd just step up to a 35in tire, but I think I'm going to save that tire size more for the fun 4x4 I hope to have in a K5 or a Burb with a 4-6 inch lift.
But to answer your question, I think a 2in lift with 31's would still look good. Probably very similar to a 4in lift with 33's. A 4in lift would probably make them look small, so I wouldn't go any more than 2in lift using a 31x10:50..
My 2wd c10 has 31x10.50x15s at stock ride height
OzarkRunner
SW MO
Daniel
GMC V1500
4" BDS spring lift on 33x12.50x15s
I wish everyone would be descriptive as your post. What type and brand of lift and the actual tire size.
Seems most will say like 6in on 37's. Now that could be 4in suspension, 2in body lift and might be 15, 16, 16.5 or 17 in rims.
jcuriel512
