How To Remove A 6.2?
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Hey guys. Im going to tear into the ol 87 Square today and remove the 6.2. Whats the best way to do this? Will it come out the top or do I need to remove the radiator and header panel?
Also, how much do these engiens weigh? My cherry picker is rated at 1000 lbs, but I DID pull a Stroker with it. I hardly doubt they weigh more than a 7.3 Stroker but Iv heard crazier stories.
philjafo
everywhere
phil
k20 scottsdale
350/sm465/np205/d44/corp14
I would remove the radiator, just to be on the safe side cause its soft. Should be no need to remove the core support though there's lots of room in the engine bay. I can't see the engine weighing in at over a grand but make sure you check the hoist the weight it can lift goes down the farther out its extended. If your really worried the hoist won't pick it up, you can always disassemble it in place. Pull the heads and crankshaft and I bet it weighs less then a small block.
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Iv began unplugging everything off the motor so Im making headway. After looking at the engine again and comparing it to the Powerstroke, I hardly doubt its anywhere near the same weight.
This cherry picker is an oldie. The arm doesn't slide in and out. Its basically a bottle jack on a bunch of metal lol.
I did go shead and take the radiator out since it was held on by 4 bolts on top of the radiator mount. This also gave me an opportunity to take out my (radiator for the A/C) since the rest of the A/C is non-existent. I think I will go ahead and take off the hood for added clearance also since I left the radiator mount on.
philjafo
everywhere
phil
k20 scottsdale
Make sure you mark the hood and hinges before you take it off so its easy to line it back up. I've seen people drill an 1/8 inch hole and use a nail to line it back up but I've always just used a sharpie to trace the hinge.
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Did it! I saw that on The Powerblock on TV and I thought "Hey, that's an excellent idea!"
The nail idea would prolly be a little complicated with something as heavy as a hood but Im sure itd work lol
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Whoop! There it is!
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Hmm.... I think I bent a few fan blades lol
mrnapolean1
'87
R10
4.3 V6
Had a 84 6.2 diesel truck that was a project.
Me and my dad removed the 6.2 motor (dropped jug) out of it to swap with a Carburated 350.
Removing the radiator will make it easier to pull the motor out. This truck was a granny gear 4 speed.
HectorGarcia415
