How To Refurbish Your Dashpad
BTW I PM d you about some picture issues im having Hotrodpc
Huh??? :shrug: When I get back I'll check and see if I missed any messages. I didn't get an alert anyway, but I'll check my inbox. Sorry
MadOgre
NA
NA
NA
NA
NA
Ok Thanks. just cant figure out how to upload pictures evertime a box pops up asking for URL ?
diaric
Alberta
Richard
6.2 L
That turned out fairly good. How does this end up being as far as weight?
Its probably ounces more than it was stock. The best fillers would probably be flexible stuff for bumpers but I didn't want to pay that kind of $$ to test how well it would work.
The only rough spot is the right hand corner where I didn't notice it wasn't blocked well. I might put a 6.2 emblem over it and no one will notice.
Test fit after fixing the edges, filling the cracks and sanding the foam down.
Surface pretty much prepped for the final coat.
garzas23
Brazoria County TX
AJ
I originally intended to stop here, but I didn't like the finish on it. So, I went back to the hardware store(again) and bought a couple cans of Krylon Fusion satin black. This stuff is great because it will bond to darn near anything. They have a large selection of colors so you might be able to find one that matches your interior. Follow the directions on the can and paint right over the bedliner. If all goes well, you'll end up with this.
So you painted over the bedliner coat? Did you sand it over again also? Did you intend on doing it in that order with the first coat being a bed liner paint or was it that you just really didn't like it.
Stroked
Beloit, Kansas
Jared
Whew, this was a while back and I have a terrible memory. I intended on spraying the bedliner and leaving it at that. If I recall, the resulting finish was fairly rough and I figured dust would stick to it big time. Also I was hoping for a little more gloss.
No sanding. I just sprayed right over the bedliner and it's still holding up great.
I will add that it has another good sized crack in a completely different area from the original cracks. I suppose it's still crappy old hardened vinyl underneath so it's bound to keep doing it.
neginfluence04
Oklahoma
Melvin
K10 Sub
I gotta give this a try maybe I can mold a center channel in the dash pad
ADTrumble
Pulaski
Anthony
Verry nice
Will b trying this verry soon
And may redo interior door panals the same way to get matching texture
steelburner83
maine
joshua
V3500
7.4L
very nice fix for budget builders like myself, I might have to try this out sometime
Cheynemitt
Pembroke Pines
Jack
I have a dash pad I'm starting to do myself. I will post pics
Darkrider
Lloydminster Sk Canada
Custom Deluxe/Sierra
Hmmm Great thread! May have to give this a try if i cant find a decent pad in one of the many parts trucks i have access to. By cutting out the perforated areas for the corner speakers im wondering if it wouldnt be possible to fit some after market speakers in the stock corner locations now. From what i have read its usually the small tweeters on the after market speakers hitting the pad material that caused fitment problems. Your computer grille idea gets around that it seems...
yevgenievich
Viktor
sad
very sad
less sad
I have used an overlay and cut the original speaker grilles out to fit speakers with small tweeters.
bucata206
Silverdale WA
Anthony
When you did this, did you use just the 2 part epoxy to make the surface even or did you have to put something over the epoxy?
justin71105
US
Justin
Trying this out now, mine is pretty bad. Actually I cannot cut back far enough to reach vinyl that does not crack. Still going to attempt it, if it doesn't come out well enough I will order a replacement. So far I have sprayed some foam to find out i did not cut vinyl back enough. May just leave it brittle plastic weld cracks and spray a couple coats of krylon over it and see how it holds up.
Sent from my SAMSUNG-SM-G930A using Tapatalk
84chevk10
Mine looked like yours, I spent a ton of time on it but it actually cracked in 3 places moving it around.
dpickett1981
