How do yall ground your Alternator?
mavtricks71
az
mike
Just need information on how to add a ground to my Alternator. Should I use a ground Strap or an insulated wire?
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Stock trim they usually ground to the engine block through the housing.
To upgrade add a heavy gauge wire to the frame or negative battery terminal
Stereo guys running big amps do the “Big 3”
- heavy gauge charge wire
- heavy gauge Alt ground to battery
- heavy gauge body ground
Or the big 5 which adds
- heavy gauge engine ground
- heavy gauge ground from battery to frame
Here’s mine partially done, one of the blue 4ga cables to the batt lug of the alternator and the alternator ground is 4ga to the frame. 0ga cables from the frame and fuse block to the battery.
mavtricks71
az
mike
Would it be ok to run my 6 awg ground wire to the block or frame? Instead of running it to the battery my alternator is now on the drivers side. 350 ho engine.
CalSgt
CA
Casey
Yes, not much point in running it to the block though. It’s already ground to the block through the mounting bolts
RustyPile
Elkhart, TX
Nick
1983 GMC
350 SBC
The battery negative cable is attached to the engine block. If not, it should be.. The alternator is bolted solidly to the block. If not, it should be. This question begs to be asked --- Why do you need another ground path for the alternator??
mavtricks71
az
mike
The Brackets on my truck are Aluminum holding the Alternator does this still ground the Alternator?
Doppleganger
OH-MI: Just like it sounds
I would use an insulated wire - never saw a strap used unless it was from a wiper motor or block to the chassis.
RustyPile
Elkhart, TX
Nick
1983 GMC
350 SBC
Think about it.. The alternator housing is aluminum.. Check out a factory stock aluminum accessory bracket on the engines equipped with a serpentine belt arrangement. From the factory, these have no "ground wire" attached to the alternator..
So to answer you question -- yes, your alternator is already properly grounded, so no additional grounding is necessary.. But if it will make you feel better, add some ground wires, including a ground wire for the alternator.. Put a ground wire on the starter and the horns.. Don't forget to put one on the steering column, distributor and radiator. All these components have aluminum as part of the assembly. The more parts you have, the more chances you have for something to fail...
All sarcasm aside.. You're overthinking and worrying excessively about this ground wire for your alternator.. Forget it and find something else to satisfy your A.D.D. I've explained how ground paths work, so I'm moving on to other more important issues.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Some companies recommend adding an alternator ground. Im guessing just the higher outputs. Mechman recommended I do it for their 170 amp.
Bloodhound1981
MA
Rusty
C-10
I think some people are getting confused with aluminum conducting electricity (yes, does so very well) with magnetism (nope not at all). Maybe because the whole positive/negative thing for both, I don't know.
adhkjashda
