High pitched squeak in the front
83kid
Massachusettes
Hi,
So i have an 83 k10. When driving, i hear a high pitched squeak coming from somewhere up front, i am assuming something to do with something down by the axle. Gets faster as you go faster, is usually there but sometimes if you brake a bit then go again its not there. Could be something rubbing, i have no clue. Any ideas?
Thanks!
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
Can you check to confirm if it is vehicle speed or engine speed related?
While driving the truck put the trans in neutral to see if the noise stays constant with vehicle speed and rev the engine to see if it changes with engine speed.
83kid
Massachusettes
I didn't have a chance to try that, but its certainly vehicle speed related, and not engine speed related. When you go faster, the noise is more constant, although it isn't always present (I dont think, bit hard to hear it over the noise of the exhaust).
buddy_1
Humble, Texas
Buddy
c2500
350 ci
Brake pad wear indicators?
83kid
Massachusettes
What about it?
And, i believe it has something to do with the brakes. Pads are good, have about half the meat left on them, but when i brake it squeaks. No big deal, doesn't really bother me and i know many other vehicles do that no matter what you replace to try and fix it. If im driving and i hear the squeaking noise, im able to tap the brakes a good bit and let go quickly and it stops the squeaking till i apply the brakes again. I'm thinking that th brakes arn't fully disengaging, and the noise is just the squeaky brakes being very slightly applied. IDoes this sound right or give anyone any ideas?
Thanks!
chengny
What you report is a textbook brake wear indicator sound.
Sometimes those brake wear indicating tabs are set too far in.
The brake reman people intentionally set them that way. The result is that they start to make the squealing noise way too early - even when there is plenty of pad material left. This causes pre-mature pad replacement and an increase in sales.
Try bending them back just a bit, take it for a drive and see if the noise abates.
83kid
Massachusettes
Sorry, completely forgot about this thread!
So, i went to look for the indicators, but i dont see them anywhere... where can i find them at to bend them back?
Thanks!
350runner
tx
Ceasar
On the brake pads. Note they are there for a reason and you know the pad could crack
83kid
Massachusettes
The pads have about half the meat left on them, so i dont see why they would crack unless they were worn more.
Raining now so i cant go look, but so i visually know what to look for, is it like this:
http://www.youfixcars.com/images/pad-wear-indicator.jpg
Or, is it more like this:
http://i.ehow.com/images/a02/70/91/checking-wear-indicator-brake-pads-800x800.jpg
If its like the second one, i looked hard and didnt see anything like it..
Do you have to remove anything to see the indicator, or can you just go under the truck and see it?
Thanks!
ethansk5blazer
