HELP proportioning valve location
MadMadi
Florida
Madison
(85 k20 3/4 ton 4wd front disk, rear drum)
Is the proportioning valve supposed to be mounted up under the front of the frame or up by the master cylinder? One piece at a time resto project and not sure if this is right. Pictures are attached.
bluecamden85
Ohio
Sierra
Mines by the front of the frame. At work no pics
SquareRoot
Front cross member. I have the same truck.
MadMadi
Florida
Madison
Any suggestions on what to get for a new one that’s not junk? Thanks!
Jeff Lewis
Missouri
Jeff
On frame. I cut a square hole in lower fan shroud to ease access. Then glued (epoxy) tabs on the cut out and mounted back with screws. Suggest Nicopp brake lines. Bend by hand.
cstew47
colombia
craig
Mine is located on the frame front. I couldn't find it for a while until I installed a new one.
spartantx117
