Help! Pinion Bearing question
Don5
West Virginia
Don
k15
So my Pinion seal is leaking on the dana 44. Since I am going through it I figure I might as well replace it as well. So I tear into it and replace the seal. I notice that there is some play in the pinion gear. Hmmm.
So my question is this- Is the pinion supposed to have some up and down play?
I am thinking that the bearing is worn and needs replaced. Everything on the front end points to it being original and nothing replaced inside. I figure since it is a 78 model it will probably need replaced. What do you guys think? :popcorn:
BTW- I have never set up a ring and pinion so this will be a learning experience for me. I checked the ring gear for any side to side movement and there is none. I thought it should move a little but it did not move any.
I am ready for a beer or two and I don't drink.. Someone can drink several for me......
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
There shouldn't be any play in the pinion or the carrier. Redoing a diff gets pretty involved with all of the clearances and measurements that have to be made, and there are a few special tools that you'll need.
Don5
West Virginia
Don
k15
Yeah that is what I thought. I was afraid of that. I picked up a dial indicator from HF the other day. I thought this might happen. Thanks.
firebane
Calgary, AB
Curtis
You know it seems like a dark art to do ring and pinion setups but honestly it doesn't seem like it would be too difficult to do and honestly something that I'd be interested in learning.
And unfortunately you own a 40 year old truck and they cause us frustration.
Don5
West Virginia
Don
k15
Cmon down and you can learn with me...:):):):) Ahh I am going outside and beat my head on a tree now...:mad:
chengny
The D44 shop manual. Download from Deposit files (no PW):
http://depositfiles.com/files/zs5ob5uct
For help downloading from DF (it's free and safe) see post #8 here:
http://www.gmsquarebody.com/forum/showthread.php?t=6290
Or get it straight from Spicer:
The complete repair procedures from Dana for axles used in Our square bodies and others too,including the Dana 44 and 60 series, rear and front steering axles including hubs too.There is even one on the "Corporate" axles too.
http://spicerparts.com/literature/li...der=ASC&=Apply
Thanks to MrMarty51 for the research and the link.
PrairieDrifter
North Dakota
Mason
I look at it as being more intimidating than building a motor for some reason, in all reality its not that bad its just tedious and you have to have lots of patience. Dial indicator is a good start, you'll need a press unless you can take the pinion to a shop you trust. The biggest thing that sucks to do by yourself is crush the crush sleeve on your pinion when installing the flange you need a big long bar with a slot in it to put two bolts into the flange and then the bar will be how you hold the pinion still while torqueing down the nut, it takes quite a bit of effort the last time I did it, it took two people I think its like 160 ft lbs or something like that and you if you go past the crush spec you have to start over with a new sleeve. That's just one of the steps too haha
MadOgre
NA
NA
NA
NA
NA
All of those links except DepositFile gives me "page not found"
DepositFile is I dunno lol
chengny
Don5
West Virginia
Don
k15
I agree with you. I would much rather build a engine. My neighbor has a 12 ton shop press so that is no problem. I helped a friend of mine set up the rear end in this truck and the crush sleeve was the hardest part of the job. I think that is why I am dreading this project.
In the old days I would have looked around and bought another front end to roll under the truck. That is not an option in this day and age due to the age of the truck. It seems that parts are getting harder to find around here at least. Oh well I will press on..:)
Don5
West Virginia
Don
k15
chengny
Hahaha, I get it - "press on"
MadOgre
NA
NA
NA
NA
NA
Don5
West Virginia
Don
k15
I ordered a master install kit for a dana 44 from Summit. It has everything except a new ring and pinion gear. I talked to my neighbor about using his press. He said no problem so that is taken care of. I have a craftsman inch pound torque wrench that starts at 25 inch pounds. I have the dial indicator from HF. I am really dreading this job. It will be a good learning experience for my son and I though.
DucatiDave
