Help identifying suspension
Onelinez
Utah
Andrew
So, I have a 1976 K10. And the person that I bought if from didn't know much about the truck. I know that it has a lift on it and was wondering if anyone could help me with identifying the springs, etc... The rear shocks are the what the stock configuration requires (I measured them) but they are fully extended at the top of the shock travel and it rides like crap and clunks like crazy when going over bumps. I would like to have as good of a ride as I can get...knowing that it's a K10 and it's not going to ride near as nice as it's C10 counterparts.
nvrenuf
Mobile, Al.
The front springs look relatively flat which makes me think 2.5" / 3" lift BUT the rear appears to have 4" tall blocks.
That said, a stock truck will measure approx 8.5" between the top of the front axle tube and the bottom of the frame. Any difference is the amount of lift.
Ex: measurement is 14.5"
14.5" (actual) - 8.5" (stock) = 6" (lift)
Onelinez
Utah
Andrew
Ahh...I'll go out and measure things. That is awesome information! Thank you so much nvrenuf!! I should have posted a picture of the truck and how it sits.
I got 10" in the front. So, 1.5" of lift...that sounds kinda small.
Washington
What size are those tires?
And sweet looking truck btw!
It will probably ride much better with some appropriately sized shocks. I agree, it looks like a 4" lift
Onelinez
Utah
Andrew
By appropriate sized…Something along the line’s of 21.5” extended? Trying to get some ideas on what others are using.
Onelinez
Utah
Andrew
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Are you measuring from the top of the axle tube or the top of the springs, or maybe the edge of the diff housing? The way it sits looks to be about 3" to me
BTW my wife says 1.5" is just right
nvrenuf
Mobile, Al.
I agree, not a ton of lift but definitely more than 1.5”.
I’m using Tuff country shocks from ORD. They have a chart that tells you what shock to use for a certain amount of lift. You can also do it the right way and disconnect the current shocks, measure the length at rest, then lift the truck by the frame until the axles are just dead hanging with no shock attached. Measure it again and just call a shock manufacturer with those numbers. They can give you a shock recommendation based on those measurements.
Onelinez
Utah
Andrew
So...I am reviving this thread because I want to put 4" leaf springs on the front. Would anyone recommend just doing the leaf springs in the front (I have new shocks for a 4" lift)? What else am I going to need (ie. drop pitman arm, etc..)
Thanks for any help!
It looks to me like you have 4 inch springs already. Maybe sagged slightly. So it will basically be a direct replacement to go with softer 4" springs, assuming there is already a raised steering arm installed. In the pictures earlier, I can't tell.
Onelinez
Utah
Andrew
Thank you for the reply...and sorry it took me so long to get back. Been out of town on business...
Anyway - I have attached a picture of the steering arm (which looks to be raised). The reason for wanting to replace the springs is that in an earlier post it appeared they were maybe 2-3" lift springs. As you can see from the picture the tire has been rubbing on the front drag link. As much as I hated to do it I had some 1" wheel spacers laying around and those moved the wheels out enough to clear that drag link. Now my issue is that it's rubbing on base of the fender.
rogueakula
