heater command (loose lever)
roadwolf
France
Rodolphe
silverado 10
When i bought the truck i had heat in the cabin, but on the way back home, the lever got loose with no effect on the heat selection.
i have the climate control unit, is it easy to acces both end of the command cable, what parts must be removed to fix the problem ?
roadwolf
France
Rodolphe
silverado 10
i have fix the problem, will post pictures soon if it can help somebody else.
MrMarty51
Eastern Montana
Martin
Thank You,that would be nice.
I was always a bit hesitant to remove them heater controls,not being able to get them out to whare a person can get to the retainers,etc,is a real pain in the butooski.
roadwolf
France
Rodolphe
silverado 10
To access the vent/heater control, you have to remove the cluster bezel.
- remove the screws of the bezel and its lower part under the steerin column
- remove the knob of the radio by pulling them
- in case of tilt column don't forget to put it in the lower position
you should see this
to get the vent/heater control you just have to remove the 4 screws, now it s only hold by the command cable and the wiring harness
i just had to reinstall the loop of the cable on the pin after removing/puting back the lock shim and put the red square platic part of the cable in the hole under the controls
The hot/cold is controlled b a cable.
MrMarty51
Eastern Montana
Martin
you should see this
Hows that red plastic clip come out of the hole,a couple of them squeeze tabs on the back side ????
There is a squeeze tab on the housing that goes into the hole in the red tab on the cable, couple a pics:
Pictures of the cable end at the top of the heater housing behind the glove box. Sometimes that screw holding the red tab works loose and the cable slides a bit trying to adjust the heat:
MrMarty51
Eastern Montana
Martin
Well,I guess that clears that question.Being half blind and not being able to get that control out to where it can be viewed is/was My biggest problem.
Thank You for Your reply.
I`ve a bunch of work to do on the heater controls of My 79 and,so this`ll be mighty helpfull.
I plan to have all the a/c and heat stuff yanked out of the '89 and in storage for times like these so I can get the pics you guys request. :)
MrMarty51
Eastern Montana
Martin
What a nice idea.If you would be so kind,send them over to Me,I`ll store them under the hood of.............OOOOOOOPPPPppppsss sorry,I meant to say,In My shed.:cheers::popcorn: :happy175:
roadwolf
France
Rodolphe
silverado 10
i think the mechanic that change the cable, didn't know where to put the red plastic clip, i have an invoice withe the cable price writed on it.
mike
Need help with climate control cable? My original cable broke ordered one from LMC. Can anyone help me with how to connect and adjust cable to right length? Right now it is connected, it slides fairly easy when moved to hot, but when I slide it back to cold it gets stuck. Don’t want to force it! Thanks
Misty Blue
