- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
Maybe I'm missing it here... But my defrost setting doesn't work. Heat blows really hot into the cabin, but I don't get a thing from the vents up by the windshield. What should I look at? Defroster actuator? Where do I find it?
If you have air conditioning the defrost door is right above the floor heat outlet, the vacuum servo is on the side facing the accelerator pedal.
If you do not have a/c a cable controls that door.
Thanks to the OP for these photos (Mr. 89Suburban) - hope he doesn't mind that I wrote graffiti all over them:
Take that diffuser off like chengy said and see if that trap door is moving. Did you do that? I'm about all out of advice for you. We put a lot of diagnosing info here but you don't seem to be following it and reporting back, just asking the same thing.
Plug the vacuum hose back on and take that diffuser off and see if that trap door is moving or not with the controls.
By the way yes there is a seal against the firewall and if it is shot it will blow some air behind the housing but not enough to affect your other functions unless the whole housing itself is loose. Is you housing nice and tight to the firewall or can you shake it?
