Headlight Drama...
quadracerx
Graham, WA. USA
Steve
I am just getting my 84 GMC Flatbed sorted out...
Two of the headlights on the drivers side were broken, so I replaced all 4. I havent driven this truck in the dark in years... So here's the rub, drivers side both high and low beam headlights are bright. Passenger side low beam works but is dim. High beam has no light...?
As a side note the marker on the passenger side fender has no light and the signal in the grille on the passenger side has no light?
I havent had a chance to check any further as it started to pour outside and it was getting dark anyway...
So soon as the weather clears I will check for power at the bulbs that have no light and the condition of the two marker bulbs...
The wiring on the passenger side low beam headlight has two black wires going to the plug, are they both ground??
Any ideas on this if I have no power at the bulbs on the grille, fender on the passenger side?
Thanks for your help...
Steve
87silveradok20
Ohio
Levi
Silverado k20
Check your grounds. There’s a different one for each side and that’s what it sounds like your problem is
quadracerx
Graham, WA. USA
Steve
Ok, ill admit my total wiring stupidity.... Where would the lights be grounded typically?
I hate sounding like a dumb ass... But everybody's a dumb ass sometime....LOL
Thanks,
Steve
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Thanks,
Steve
On the radiator support on either side above the headlights black wires with shakeproof ring terminals. Check your headlight connectors they get weak and break and will cause the same issue.
Camar068
10 yrs Air Force
yup missed that while putting front back together....easy to miss, specially passenger side as it's a short wire.
quadracerx
Graham, WA. USA
Steve
Thanks so much for the help!! And for putting up with my dumb ass-ness...LOL
Ill check it out as soon as it stops monsooning here... Which could be July...
Thanks again,
Steve
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Thanks again,
Steve
:waytogo: And looking for knowledge is not being a dumb ass. Hacking **** and not asking is.
X Whatever. It's the grounds. Take the bolts loose with the star washers. Hit that section where the bolts and washers go with a little steel wool or sand paper. You can also put a finger swipe of vaseline if you wish and then tighten back up.
This isn't P4x4, so you gotta be pretty damn stupid be considered dumb ass here but that's not one of them. A dumb ass would be the guy that gets it fixed and doesn't come back and let us all know what solved the issue.
You should crochet that on a pillow.
:33:
Ohhhh, so Honkey Donk is the one we see to make us reusable terlet paper. :shrug: Whooda Thunk it?!?!?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I think he meant embroider but that’s ok lol
gmachinz
Harnessworx Inc
Iowa
Jabin
On the passenger side the grounding ringlet also has a larger lead going down to the frame as well. The ground wire on that side goes:
high beam to low beam, low beam to core support ringlet, core support ringlet to top of frame near fuel pump location.
rowdy_80
