Harsh shift from 1st to 2nd
NO TV/Detent cable on a Th400. Has an electric kickdown solenoid and that's all it does is downshift.
Ya I fugged up, I was thinking 700r4. :sorry:
Maineguy10
Maine
Erik
K5 blazer
6.2 diesel
So I put a piece of fuel line as a new vacuum line just to see if that would help, and it solved my problem, so I must have pinched the hard line when I reinstalled the tranny, easy fix, I will run a new hard line tomorrow,
Thanks for the help!
That'll do it. Glad you got it resolved. But, now you know. There is only 3 things, provided the fluid level is good, that will delay shifts on a Th400. Vacuum Modulator or Vac to it, Governor malfunction, or stuck kickdown solenoid. And you don't have to have the kickdown connected either. Trans functions the same with or without it hooked up, EXCEPT it won't downshift into passing gear.
Maineguy10
Maine
Erik
K5 blazer
6.2 diesel
Awesome, thanks again hotrod, you were a great help, Lang with everyone else! Hopefully ill be able to pass along some knowledge someday too, good forums are such a great tool!
bigcreek
