Get better MPGs out of 454?????
rogerz53
illinois
cody
v30
I have a 1988 Crew cab 1 ton 4x4. Im trying to improve my mpg. I know it wont be good, but I only get about 150 miles per tank, (31 gallon tank). Any ideas?
johnmc
mass
john
k 10
305 tuneport injected
even my p 30 chevy chassis 28 foot RV with a 454 tbi gets 11 mpg. @60 mph. does it run good? is it loaded up heavy? you could add duel exhaust , tune up?
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
i would say the best thing you could do is make sure your injectors are in tip top shape, do a full tune up with AC Delco tune up parts, run a good synthetic in the engine, trans, and rearend. make sure the cooling system is clean, and keep up on the tire pressure.
Anything beyond that, I would contact CFM-Tech and get their TBI package, comes with a few parts that optimize throttle body/air cleaner setup, and an adjustable fuel pressure regulator.
rogerz53
illinois
cody
v30
Thanks guys! My truck is already a TBI, It does need exhaust. I was wondering what size pipe I should use. It has 3 " now but I think that is too big. Any advice on that? The truck does run well. Its not loaded down, but it is a 1 ton.....
Jims86
Patterson,Ca
5.7 TBI
If its single 3"' it should be just fine for a 454. if you have duals, i would say 2 1/2" should be more than sufficient. go with a straight through design muffler, the longer the muffler, the mellower the exaust will be.
rogerz53
illinois
cody
v30
Awesome, thanks a lot
1983_SB_4X4
Dewees, TX
Rob
Gears & Trans type also will affect your mileage.
Yes, this. Also make sure to check the timing with the single tan/black wire disconnected. You should be able to pick up a fair amount of mileage. My '79 1 ton 4x4 crew cab dually even gets 10 mpg.
Bagged Dually
Joplin,Mo.
Kris
CUMMINS 12 valve
I've been working on this same thing with my 1 ton TBI 454. So far I've done headers with 2.5" duals, tune up, and little things like tire pressure. My next thing is going to be gears. Mine has 4:11's in it. If yours has 4:11's and your not pulling much you can get away with something a little taller. I'll probably got to a 3:73 and see how that does.
rogerz53
illinois
cody
v30
Awesome advice again! Im really glad I found this website/group!
lepak
