Gauge cluster rebuild guy
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Found a guy who rebuilds your gauge cluster. I don't know what he charges yet but he said send him an email and he will send all the info back to you. His email address is [email protected]
Name is Jeff Drew. Here's a pic of his work.
Looks pretty sharp to me.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
Do you know where he is located?
82sbshortbed
Fuckemall!!
SE Texas
Doug
No not yet.
Looks very nice.
I'd love to see my Jimmy bury the speedo and shift around 10 grand too.
82sbshortbed
Fuckemall!!
SE Texas
Doug
www.73-87.comGauge Cluster Order Form
[email protected]612-558-1666
Customer Information
Last Name:
First Name:
Phone Number:
Text Capable Y/N:
E-mail Address:
Shipping Address:
Vehicle Information
Year:
Make:
Model:
Cluster Build Information
Column or Floor Shift:
Autometer Gauge Series:
Speedo/Tach Size: 5” (default)
Oil/Water/Fuel/Volt Size:
Additional Information:
Parts List (Customer Provided)
Dash Bezel
Gauge Lens
Gauge Cluster Housing (no broken or missing mounting tabs)
Autometer Gauges
5” tachometer/speedometer
2 1/16” or 2 5/8” oil/water/fuel/volt
Indicators (www.jegs.com)
555-11063 or 764-80205 (qty 2)
555-11061 or 764-80206 (qty 1)
Terms & Conditions
Price for each cluster build is $275 US dollars. This price includes laser cut adjustable aluminum brackets for gauge mounting, and all labor to complete cluster build. Customer to provide all other parts. Payment is not due until cluster build is complete, acceptable payment options are PayPal or cash in person. Customer is responsible for all shipping, of which I charge a flat fee of $50 (continental US), and refund the difference once cluster is shipped.
Disclaimer
Gauges will be modified to fit flush against the back of the dash bezel, this process requires removal of the factory trim ring and re-mounting of lens directly to the gauge housing. While I have built several dozen clusters by doing this with no issues, modifications such as this will void any warranties to the gauges, should there be a manufacturer defect. By hiring me to build your cluster, you are acknowledging this disclaimer and are fully responsible for the gauges once they leave my possession.
Recommendations
Buy a new dash bezel, it will look much better than an old or faded unit (www.LMC.com has very nice dash bezels)
Purchase a Painless Performance Universal Gauge Wiring Harness, makes wiring the gauges in much easier (PN 30301 or 30302)
Upon cluster installation into vehicle, remove all dash pad screws and drop the steering column down as far as possible. It is a tight fit to squeeze in the cluster assembly, having these parts out of the way/movable will make installation go much smoother
82sbshortbed
Fuckemall!!
SE Texas
Doug
There's the info he emailed me back. Less than half of a new one that's about $900. He's in Minneapolis, Minnesota.
91Sasquatch
Portage, Mi
Michael
Suburban
My speedo just quit on me this weekend.
Battlac40
New Mexico
James
K1500 Sierra Classic
Drooling, waiting to see someone get one , I want shinny new goodies too
Clif Bakx
Grunthal, MB
Clif
GMC
That Dash looks awesome, i'm going to call this fella up.
Say, my 1980 project is closing in on interior work, and i'd really like to know if the interior components (specifically all dashboard stuff) from 1981 / 1982/etc will fit my 1980 truck? I'm not looking to absolutely have a 'year-correct' truck; i like some of the '81+ features better than '80 down, like the dash bezels, trim, etc.
Also, my truck had the older style one-wire dual tank solenoid, with the old style rocker sw in the dash panel.
I went to the newer style 5 wire fuel tank solenoid, and the required dash switch... but i'm pretty sure looking at the sw that it will not fit in that same dash hole. Is anyone out there working on a '81+ truck that can tell me the opening dimensions of the newer dual tank dash switch?
Thanks!
Clif
82sbshortbed
Fuckemall!!
SE Texas
Doug
I've got an 82 with the tank switch mounted by the ashtray. I'll have to measure it to tell you the dimensions of it tho.
Let us know if you get this guy to do your cluster. Looks like he does a really good job. I wanna give him a shot at mine when I get to that point.
Craig 85
Nashville, TN
454/TH-400/NP205
They will fit the 80'. Here's my '79 with 81 & up interior parts. I think you can use the dash bezel up to an '84 as it has the hole for the wiper switch on the dash. There are minor differences in the lower dash plastic trim and the right side A/C vents, so I bought those during the switch.
Clif Bakx
Grunthal, MB
Clif
GMC
That dash looks great! Well done.
By the pics in the LMC catalog, the '81+ main plastic bezel has chrome inner rings around the gauges, but '80 down don't, so i was wondering if i was stuck w/ only the older stuff.
Yah, if you could measure that dash slot pretty precisely, that'd be great. Looking at this new switch, once it's pushed in it looks like a b#*%h to get out... plastic crap.
Clif Bakx
Grunthal, MB
Clif
GMC
Craig, in those pics, is that brushed aluminum bezel cover the aftermarket one from LMC? i noticed it doesn't cover the lower 3rd of the main dash.
Clif
Craig 85
Nashville, TN
454/TH-400/NP205
Clif, the 81 & up does not have the lower trim like the '80 does. The trim face I got from LMC. IIRC I had to bend the trim to match the contour of the bezel. I got a used bezel on eBay and painted the whole thing black, then repainted the letters. I kept having issues with the trim staying on the bezel.
The door panels were Scottsdale models (no cloth inserts), again from eBay that I resprayed. The door trim is available without the grab handles.
The VIN opening in the dash is a little different between the 80 and the 81 & up. Part of your VIN will no longer appear through the opening.
Clif Bakx
Grunthal, MB
Clif
GMC
Thanks for the helpful info Craig!
Clif
Charkmapman
