gas filter goes empty?
JohnRod
Kingman,AZ
Rod
2500 Suburban
I have a 76 2500 2wd Sub. have had it since 1982. if it sets for an hour the gas filter, which I have just above the pump and is clear plastic, goes empty. this makes for hard starting, since the gas line between the filter and the Holley carb. also drains. I have removed the gas cap as soon as I park, thinking the vacuum in the tank might cause this. but no.
my 67 C-10 will set for 10 days and still have gas in the filter.
So, is this a problem with the pump, allowing gas to go back to the tank?
thoughts/help would be appreciated.
thanks Rod in AZ
SirRobyn0
Rob
Ok we just had a discussion about drain back in another thread that let just say there were some strong opinions about it, but I'll give you my experience. You can spend a bunch of time trying to correct the drain back issue, but a good strong fuel pump should be able to over come a drain back issue without any trouble. For example on my truck, a couple hours after it has been turned off the fuel line from the pump to the carburetor will be dry inside, but it will fire right up, because the pump is good and strong and can build pressure quickly. So it's most likely a pump issue. If you have tested your fuel pressure and volume and its ok then there is another issue causing hard start.
SirRobyn0
Rob
The more I think about it this doesn't really sound like drain back to me. It my well be draining back, but after only an hour of sitting there should be plenty of gas in float bowl still to start the engine.
Even mine takes a day in cold weather, but week+ in warm weather to have a trouble starting.
aaron06
