Fuel tank question
Keuka C10
Finger Lakes NY
I have a 84 C10 with a 350 and Rochester carb. I will be replacing one of the fuel tanks and I got to thinking. I know if I ever want to move to an LS fuel injected motor, I will need the 87 model baffled tank. Would I have any issues if I just did that now since I have to get a new tank anyway. Will the current 84 sending unit work in the 87 baffled tank?
Thanks
RoryH19
Rory
R10 Silverado SWB
The FI tanks just have a baffle to hold a pool of fuel around the bottom on the fuel pump pickup.
This way the pump isn't starved of fuel when the tank is low.
Assuming the sending units are the same size/height it would work.
When you go LS you will need a new fuel pump and sending unit.
AFAIK the '87 tanks are the same, except for the added baffle, and the price is similar to the older tank.
If you switch to an EFI pump in an older tank you can add something like the Holley Hydramat to keep fuel flowing to a new EFI pump, but the Hydramat is not cheap. Another option is to use a surge tank setup where the stock pumps feed a small tank that has the EFI pump immersed in fuel.
This Fuel Command Center is a pre-packaged surge tank that includes the pump and all the required connections for EFI. Its relatively expensive, but includes the EFI pump, ability to run a return line, and all the other features you need to support EFI. Since its fed by the stock fuel line to the old carb, you can have it connected to dual tanks without any mods to the tanks. https://www.summitracing.com/parts/hpf-40004/
78ALB
