Fuel Sending Unit Issue
DILLIGAF956SSG
OK
Johnny
C10 Silverado
5.7 V8
Hello I have a 1985 Chevy C10Silverado that does not mark fuel on gauge. Gauge work fie till truck was parked and moved after 9 months due to work. I replaced gauge new wiring and sending unit. Tried pretty much everything from small fuses to purchasing everything what's next? Please help any ideas or suggestions will be appreciated. Thanks in advance.
ffgig
US
Sam
I had a problem with mine not working and it turned out to be a grounding issue. My dash harness was making good contact with the printed circuit on back but the grounding was not good. I just tapped into the ground wire with a pigtail wire and found a new ground and it worked.
DILLIGAF956SSG
OK
Johnny
C10 Silverado
5.7 V8
Thanks I sure will try that because everything else is new. Thanks again
Yep, 90% of the time when these guages fail it's a grounding issue and usually doesn't cost a dime to fix. It's a matter of chasing down the grounds off the top of the fuel tank at the sending unit and rough up the metal and connector while cleaning with some sandpaper and that'll usually solve the problem.
You coulda come here first and saved some cash and headache. :bawl:
Soooo Welcome to GMSB. Where you at in OK Johnny?
DILLIGAF956SSG
OK
Johnny
C10 Silverado
5.7 V8
I'm in small town named Beaver.
Ahhh, you're way up there in the pan handle where all the fires were recently. Hope you guys are recovering well and you didn't sustain any damage.
You're a bit far for me to swing by and take a look though. But do check your grounds at the fuel tanks. They probably need removed, cleaned with a little sandpaper and re attached then you should be good to go.
Be sure to let us know how it turns out and it that fixes the problem or not. We'll be here when you need more help.
Thread Moved to : Eletrical and Audio > Gauge, Speedo & Instrumentation.
If you had it bookmarked, update your bookmark. Thanks, HRPC
