Front coil spring rates.
78C10BigTen
pennsylvannia
C10 BIG TEN
Ok so im looking at new coils for the front of my 78, auto store has 2 listings, both for my big ten. One is a regular constant rate coil with a rate of 843, the other is a hd constant rate spring with a rate of 1060. I dont know what spring rates are so im a lil lost here. Is my big ten factory with hd? I want it to sit level to the back end as i have a low nose stance right now. Anyone learn me here....
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
The nose slightly lower is normal. Tired springs may exacerbate this. The higher spring rate may be for big block trucks.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
spring rate 843# per inch of compression or 1060# per inch of compression. f44 big 10 is most likley the heavier 1060 of the two and will give you a stiffer ride. in theory the softer spring is longer so installed should give the same ride height.
78C10BigTen
pennsylvannia
C10 BIG TEN
It is a big ten but not a big block. Id really like it to look level. It definately has a rake to the front. Thanks for clarifying the rates. How hard do you think the 1060 will right
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
the big 10 came with a straight six stock and the heavy springs. a big block required the heavy springs upgrade for the standard chassis. yes 78 had big blocks in c10s. it will ride like a truck lol.. i definitely feel the road fortunately my seat are soft
jp wessels
