Ford NP208 Interchange / 27 Spline Output Shaft Th400
silverscottsk10
trafalgar indiana
mike
Is ford np208 and Chevy np208 the same casing?
Or is it mirror imaged?
I can get a np208f for free and since I can't find a np208c anywhere close or cheap enough I don't have many choices
MadOgre
NA
NA
NA
NA
NA
I think the same era Ford drops to the drivers side :( Im not positive but pretty sure.
silverscottsk10
trafalgar indiana
mike
It does, but would the case be made the same?
It looks the same
MadOgre
NA
NA
NA
NA
NA
It looks the same
If you flipped the case all the shifter stuff would be on the bottom side of the T-case. I don't know if it would clock into the down ward position either. Most of the internals can be reused though.
silverscottsk10
trafalgar indiana
mike
What all is involved to change to a 205?
MadOgre
NA
NA
NA
NA
NA
Any I guess, I got a 400 with a 27 spline shaft
If you have a TH400 it has 32 splines. So you need a 205 from an 81 and newer truck any crew cab or 3500 truck will have it for sure. Needs to be from a TH400 or SM465. Make sure you grab the front drive shaft too.
silverscottsk10
trafalgar indiana
mike
But my input shaft into my t case has 27 splines, and it's a 400 from pan pattern
Stewzer55
Ohio
Stew
R30
Then it should be easier for you to find a 205 then, **** it, do a 203/205 Doubler.
silverscottsk10
trafalgar indiana
mike
Lol
I have no clue what that is, never been inside a transfer case too last weekend, transmissions I know, but new to transfer case as far as options that are available
MadOgre
NA
NA
NA
NA
NA
Picture of transmission please and a nice close up of the input shaft.
silverscottsk10
trafalgar indiana
mike
MadOgre
NA
NA
NA
NA
NA
I wouldn't have believed it if I hadn't seen it. Well I guess any 205 from a TH350 or a 208/241 from a TH350 or 700R4.
78ALB
