Engine wiring harness??
fish on
Harrington, De
Phil
V20
well i have looked on lmc and brothers and all the regular places and i cant find an engine wiring harness.... does anyone know where i can get one?
Thanks, Phil
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Howell EFI or Ebay. Your's burn up?
Just the engine bay harness for a TBI ECM truck? 87 4x4 3/4 ton?
Are the harnesses going to be the same from 87-91 Jim? How about 1/2 vs 3/4 vs 1 ton?
As in what all will be copmpatible with his?
:popcorn:
fish on
Harrington, De
Phil
V20
yep, 87 4x4 3/4 ton 350 TBI . It did not burn up it just has alot of wear on it and alot of broken connectors.
Jims86
Patterson,Ca
5.7 TBI
87-91. the 3/4 and 1 tons have the hot fuel module, but it can be added, or not used at all.I have seen the hfm as another problem in the mix. i would only run one if it was a fleet truck hauling a zeeman trailer that makes frequent stops.
The connectors are available new, and would be a better option than replacement of the whole harness.
Here is where I get my plugs, its a camaro shop, but the tbi and tpi camaros run the same plugs as all the other gm cars of that era.
http://tpiparts.net/82_92_camaro_wiring?b=1
MrMarty51
Eastern Montana
Martin
Aha,another one added to Mine favorites.:smokin:
fish on
Harrington, De
Phil
V20
Thanks! the link is awesome... just what i needed and saved a ton of time.
fish on
Harrington, De
Phil
V20
just got the connectors and it worked great! two day shipping and the problem is solved / saved a ton of time! Thx
Jims86
Patterson,Ca
5.7 TBI
Right on, glad it worked out!
Jim have you ever saw a place like that that has the headlight plugs for the mini-quads?
Jims86
Patterson,Ca
5.7 TBI
Yeah...the help isle.
Dorman #85897 for the highs
Dorman #85896 for the lows
hootsmcgoots
Norton, VA
Jason
305/SM465
www.truckandcarshop.com has a large selection of harnesses, both repro and NOS. However, They only have them for 73-82. As soon as I can find out if the 82 engine harness is compatible with the 86 I may be picking one up.:emotions33:
Jims86
Patterson,Ca
5.7 TBI
the only engine related stuff on an 82 is the choke, oil presure, temp gauge, ignition...unless you have the electronic timing with the knock sensor. what exactly are you trying to do?
mpitzer13
