Engine Swap = Transmission Leak
ArmyChief
Richmond, vA
Bob
Before I drop the tranny (again), asking for some input. Just completed an engine swap in 82 Scottsdale. Bolted another SBC to the SM465. Replaced the complete clutch while at it. Went to fire the motor for the first time today and fluid leaked from the bell housing. My guess is input shaft seal, but I'm listening to thoughts. Second, what about damage to the clutch from the fluid leak? Thanks in advance for any and all assistance.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Is it gear oil? Engine oil? Do you have a hyd. Clutch?
ArmyChief
Richmond, vA
Bob
Gear oil. Negative on the hyd. clutch
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
As much as it sucks probably the input shaft seal. Make sure when you pull it check for abnormal shaft play. Clutch should be free of oil.
ArmyChief
Richmond, vA
Bob
Follow up - Input shaft seal. No play, guess the seal got shoved out of place during install.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Sucky but easy fix and good on not having shaft play.
Honestly, better the input seal on the transmission than the rear main on the other installed engine.
Bowers31
